TV in garage ? - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 06-04-2012, 03:58 PM Thread Starter
TV in garage ?
What are the operating temps for a tv? Can I just hang one in the garage and forget about it? Lcd vs Plasma, etc? Not doing led or anything, trying to do it on the cheap. Anyone have a 40" or better theyre wanting to move?
post #2 of 9 (permalink) Old 06-04-2012, 04:17 PM
beac83's Avatar
Sportbike: A couple
Most electronics built for consumer use are rated for an internal maximum temperature of around 120 degrees F and a minimum operating temperature of 32 degrees F.
You can expect that the internal temperature will be 20-30 degrees warmer than the ambient air near the unit. That makes operation at above 85 or so and below 20 or so iffy. If you want to have the TV in an unheated and uninsulated garage, I'd unplug it when not using it, and not plug it in (some components are powered even when its off) in extreme temperatures.
Mil-spec electronic components and assemblies are designed to run from -40 to +140 F, and would be no problem if you can afford it.
________________
beac83 is offline
post #3 of 9 (permalink) Old 06-04-2012, 04:20 PM
I survived the buyout
Renner's Avatar
Sportbike: 2006 Ninja 250
Years Riding: Your language is offensive!
How you found us: Followed the drunks
Put a tv in my dads garage about 5 years ago with a comcast box and it is unheated....always plugged in and no issues so far
My Super Sexy Vlog
www.youtube.com/rennervlogs
Renner is offline
post #4 of 9 (permalink) Old 06-04-2012, 05:28 PM
You shouldn't have an issue.
post #5 of 9 (permalink) Old 06-04-2012, 05:35 PM Thread Starter
LCD too?
post #6 of 9 (permalink) Old 06-04-2012, 05:50 PM
Originally Posted by 2weelpilot View Post
LCD too?
Only issue i see with it is that you will probably be in a old fogies home before you get a chance to enjoy it
post #7 of 9 (permalink) Old 06-04-2012, 07:56 PM
I have a 50" DLP in my garage. its just fine
post #8 of 9 (permalink) Old 06-04-2012, 08:10 PM
I may be doing the same with my 50" DLP. That or its going into my office when I buy a place.
post #9 of 9 (permalink) Old 06-04-2012, 10:31 PM
mada faka get down
AcidDoLL's Avatar
Sportbike: Gsxr 1000 & Hayabusa
Years Riding: ask your mom
How you found us: friends
As the name "liquid crystal display" (LCD) implies, the display technology uses a substance that shares the same properties as liquids. It therefore can freeze if left in cold enough temperatures. In most cases however, it will also defrost without damage once returned to room temperature. Check the specifications for your LCD device and you'll find two temperature ranges given -- one for storage and one for use. LCDs will only work properly in a certain temperature range, and can usually be stored in a larger range with colder and warmer temperatures. Most LCDs can be stored down to -40F or up to 115F before damage occurs, but will only operate properly in a more comfortable 50F to 90F range. This varies by screen, so you'll want to check the specifications in your TV's manual. If your LCD is left out in the cold, make sure to allow it to rise to room temperature before attempting to power it on, and it should be just fine.
Over 10 years of experience and i have seen some freeze
AcidDoLL is offline
