Fire Rated cat5 Connections - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 12-05-2012, 09:07 AM Thread Starter
Got a question for you network guys out there. If I am putting a box into a fire rated wall (cutting a huge hole in a wall and replacing it with metal) and want to bring in a cat5 signal into that box, does anyone know where I can find either connections, or a semi-wall plate, or something that will bring in the signal while still maintaining a fire rating? Iím guessing this would be the same as if there was a cat5 wall connection in a fire rated wall like a regular outlet. Anyone have any suggestions of what to search for or a company that sells something that would work in this application?
Thanks!
post #2 of 9 (permalink) Old 12-05-2012, 09:14 AM
Try monoprice.com they carry fire rates cables might have something for you there. Not sure tho why you would run low voltage to a metal casing unless you haw somehog else going on there
post #3 of 9 (permalink) Old 12-05-2012, 09:19 AM Thread Starter
Yeah, the metal box is a housing, and there will be power going in there too. The network cable is just the last part I can't seem to find any info on right now.
post #4 of 9 (permalink) Old 12-05-2012, 09:27 AM
post #5 of 9 (permalink) Old 12-05-2012, 09:29 AM
Why would you put is in the same box according to code if I am not mistaken you can not nor should run Ethernet or low voltage with in 6 inch of electric. I just have a union electrician working on power in attic and I asked about the in wall Ethernet and that's the jist of what he told me. So I ran Ethernet to a separate cut and hole and called it a day.
post #6 of 9 (permalink) Old 12-05-2012, 10:02 AM Thread Starter
You looking for something like this?
http://www.fscables.com/Data/Structu...331-2/list.htm
I'm not as concerned about the wiring as that will be the responsibility of the installer. I was just thinking there has to be something that the "outside of box" cable can connect to, some sort of waterproof/fireproof connector, so that the box will maintain the fire rating.
You're thinking too small :-) Plus, I'm looking for commercial fire ratings, not worrying about in house signal interference.
post #7 of 9 (permalink) Old 12-05-2012, 10:29 AM
Still think there is code for commercial to tho I can't help solving the mounting issue
post #8 of 9 (permalink) Old 12-05-2012, 01:07 PM
Not too Slow Not too Fast
RSVMillenian's Avatar
Sportbike: 2003 Aprilia Falco
Years Riding: Too many
Search UL
Dejan
CCS very very Amateur #144
RSVMillenian is offline
post #9 of 9 (permalink) Old 12-05-2012, 05:33 PM
I'm thinking if there is a short in the electric wires, it will ground into the network wires (if they were damaged)
