why wont my FTP work!!?!? - Chicagoland Sportbikes
post #1 of 37 (permalink) Old 06-13-2006, 06:04 PM Thread Starter
I was working on this all last night it's making me nuts. I installed IIS I got the service started. I turned on UPnP on my router and forwarded port 21 its still not working! Any ideas?
Currupt247 is offline
post #2 of 37 (permalink) Old 06-13-2006, 06:06 PM
double check your outside ip address
post #3 of 37 (permalink) Old 06-13-2006, 06:10 PM Thread Starter
heres my settings on my router (in blue and white) and my IIS settings (in grey)
post #4 of 37 (permalink) Old 06-13-2006, 06:16 PM Thread Starter
i went to whatismyip.com and i have my outside address the ports are forwarded im typing ftp://ipaddress but still nothin.
post #5 of 37 (permalink) Old 06-13-2006, 06:17 PM
try pinging your dns name, do you get a response? what happens if you use the ipaddress and not the dns name in your ftp client?
post #6 of 37 (permalink) Old 06-13-2006, 06:19 PM Thread Starter
lemme try that
post #7 of 37 (permalink) Old 06-13-2006, 06:20 PM Thread Starter
There isn't a domain name on set on my router.
post #8 of 37 (permalink) Old 06-13-2006, 06:41 PM
ping your address, do you get a repsonse from the router?
post #9 of 37 (permalink) Old 06-13-2006, 07:01 PM Thread Starter
i get a reply from my external and a reply from my static
post #10 of 37 (permalink) Old 06-13-2006, 07:08 PM
are you using an ftp client? do you have it set up for anon. or is it account login only?
post #11 of 37 (permalink) Old 06-13-2006, 07:08 PM
jimzx9r's Avatar
Sportbike: .
You try a bigger hammer?
jimzx9r is offline
post #12 of 37 (permalink) Old 06-13-2006, 07:11 PM Thread Starter
no to ftp client, yes for anon. logging in
to log in im opening up my comptuer and typing it in the address bar
post #13 of 37 (permalink) Old 06-13-2006, 07:40 PM
try a client just to make sure. once this is up be sure to take off anon.
post #14 of 37 (permalink) Old 06-13-2006, 08:09 PM
RSV4win's Avatar
Sportbike: 2002
Is your PC/server address currently 192.168.1.100? Is it set static?
Do? you have mcafee ver 8 or someother firewall program? that has a thing that would block FTP, smtp, etc.
Turn it off temporaily.
RSV4win is offline
post #15 of 37 (permalink) Old 06-13-2006, 08:12 PM Thread Starter
My pc is set staticly to .100 address. My external IP is 24.15.32.237. That's the routers IP.
I do have PC cillin firewall I tried turnign it off and that didn't work. It's automatically set to allow ftp connections on port 21 though.
post #16 of 37 (permalink) Old 06-13-2006, 08:15 PM
RSV4win's Avatar
Sportbike: 2002
what happens when you go to ftp://pcname with a web browser?
you can right click in the white area an choose login as if anonymous is not enabled.
It should work direct from the pc/server
DO an IISreset (restart IIS)from the command prompt just to be sure if you've changed settings.
RSV4win is offline
post #17 of 37 (permalink) Old 06-13-2006, 08:28 PM
Why u using UPnP anyway? I had a similar setup, but i used port forwarding and it worked great.
post #18 of 37 (permalink) Old 06-13-2006, 08:29 PM Thread Starter
it works typing in the FTP://computername from my computer which is also the server. I'm trying to let people from other connections get my stuff instead of only access on my LAN
I have both enabled and neither seem to work (UPnP and forwarding)
post #19 of 37 (permalink) Old 06-13-2006, 08:32 PM
RSV4win's Avatar
Sportbike: 2002
Check the event viewer -security do you see attempts to get in?
RSV4win is offline
post #20 of 37 (permalink) Old 06-13-2006, 08:35 PM
fyi, i can get right into your ftp.
who still uses dvdxcopy? that's junk. you also have far too much hip hop music.
post #21 of 37 (permalink) Old 06-13-2006, 08:35 PM Thread Starter
o really? hm wonder why you can and some can't can u see all the files up there?
what did you use to get in?
post #22 of 37 (permalink) Old 06-13-2006, 08:35 PM
ok, using your external IP i can get to your ftp server login screen. i had a similar problem at my old job, where i couldn't get into my ftp server by going outside to the internet and back again. however from outside of the office it would work. seems it's the same case for you.
post #23 of 37 (permalink) Old 06-13-2006, 08:37 PM
logged in as annoymous, lists directories:
C:\Documents and Settings\Blazej>ftp 24.15.32.237
Connected to 24.15.32.237.
220 Microsoft FTP Service
User (24.15.32.237none)): anonymous
331 Anonymous access allowed, send identity (e-mail name) as password.
230 Anonymous user logged in.
ftp> ls
200 PORT command successful.
150 Opening ASCII mode data connection for file list.
Apps
Books
Games
Movies
Music
TV Shows
226 Transfer complete.
ftp: 45 bytes received in 0.08Seconds 0.58Kbytes/sec.
post #24 of 37 (permalink) Old 06-13-2006, 08:38 PM
I used IE, though I'm sure my ftp client would work like a champ too.
post #25 of 37 (permalink) Old 06-13-2006, 08:39 PM Thread Starter
good deal. i guess its just me ha if anyone wants anything go nuts.
post #26 of 37 (permalink) Old 06-13-2006, 08:40 PM
ya need to setup dynamic dns, with a name i can remember, cause i might sure download some stuff from ya at some point
post #27 of 37 (permalink) Old 06-13-2006, 08:41 PM
RSV4win's Avatar
Sportbike: 2002
IE did not work for me...
o well, its working
RSV4win is offline
post #28 of 37 (permalink) Old 06-13-2006, 08:41 PM Thread Starter
That's next on my list
post #29 of 37 (permalink) Old 06-13-2006, 10:40 PM
FTP actually traverses over two TCP ports, 20 and 21. One is used for login, authentication, commands, and other session controls, the other is used for data transfer. Most routers handle "FTP" correctly as a defined service, but if you are simply forwarding a single port, that might not work.
Try playing around with that.
post #30 of 37 (permalink) Old 06-13-2006, 11:09 PM
your going to have to call kevin marino of the starboyz for help...
KENNETH929RR is offline
