Remote Access... free? - Chicagoland Sportbikes
post #1 of 33 (permalink) Old 07-18-2006, 12:27 PM Thread Starter
1shadyninja's Avatar
Sportbike: ZX9R
Years Riding: 10+ years
How you found us: Gixxer Tony
Garage
Is there a way I can get access to my work pc from my home , with out paying for one of those "go to my pc "services?
First Place Oils
1shadyninja is offline
post #2 of 33 (permalink) Old 07-18-2006, 12:28 PM
pc anywhere on your work pc, then VPN into your work network from home and remote control it.
post #3 of 33 (permalink) Old 07-18-2006, 12:29 PM
Or, if your not too keen on security, you can use the canned remote desktop.
post #4 of 33 (permalink) Old 07-18-2006, 12:30 PM
+1 Kegger.
RDP within WinXP. As long as one side is secure, you should be fine.
post #5 of 33 (permalink) Old 07-18-2006, 12:32 PM
FREE - limted time http://www.gotomypc.com
FREE - forever - VNC
FREE - forever - RDC (Remote Desktop Connection)
post #6 of 33 (permalink) Old 07-18-2006, 12:33 PM
Originally Posted by Underdog
+1 Kegger.
Yeah, just make sure they put the port and protocol holes on your companies firewall. Sometimes if you have multiple public IP's its alright to MIP or VIP to the machine and hit an unused public IP. If your firewall can truly "stealth" the IP, hackers wont know there is something listening on the other end and you shouldnt have any issues.
post #7 of 33 (permalink) Old 07-18-2006, 12:34 PM
Wooohooo
XxMarsxX's Avatar
Sportbike: 2007 GSXR-600K7
Years Riding: Year 3
How you found us: This isn't where I parked my car.
Send a message via AIM to XxMarsxX Send a message via MSN to XxMarsxX
RDC will only work if those ports aren't blocked by his work's firewall which they tend to be.
-Mo
XxMarsxX is offline
post #8 of 33 (permalink) Old 07-18-2006, 12:37 PM
Go to my PC gets around any port blocks as long a Port 80 is open outbound. (if he can get a browser running he can use it)
post #9 of 33 (permalink) Old 07-18-2006, 12:39 PM
Wooohooo
XxMarsxX's Avatar
that's correct we use that at work all the time to help the less then skill computer people.
-Mo
XxMarsxX is offline
post #10 of 33 (permalink) Old 07-18-2006, 12:41 PM
Not necessarily, if the proxy is setup correctly, it will not let it out or in even if it is HTTP:80.
post #11 of 33 (permalink) Old 07-18-2006, 12:46 PM
Yes, RDP is fine...not the most secure, but what can ya do...it's good enough and I use it.
On your home pc, you need to allow your router to pass through your connection by opening the RDP port 3389 I believe.
Then you must allow your pc to accept incoming connections.
Get your public ip address...you can visit some site like ipchicken.com to get it.
Run RDP from work and try it.
If that doesn't work, you can change the listning port on your home pc to something else, assuming your work blocks the RDP port of 3389, to a more common port.
Then if you change your listen port on your home pc, you'll have to remember to dial into it with the new port number such as
67.168.13.78:newportnumber
67.168.13.78:80
post #12 of 33 (permalink) Old 07-18-2006, 12:47 PM
vnc over ssh
post #13 of 33 (permalink) Old 07-18-2006, 12:50 PM Thread Starter
Sportbike: ZX9R
Garage
well It needs to work with the firewall, And I would like to not have to pay any fees
links to the free ones?
First Place Oils
post #14 of 33 (permalink) Old 07-18-2006, 12:53 PM Thread Starter
Sportbike: ZX9R
Garage
67.168.13.78:80
is it the same ip address I get from my forums admin control panel?
First Place Oils
post #15 of 33 (permalink) Old 07-18-2006, 01:02 PM
Would have to know how your network is setup. Youre probably NAT'ing out from a single IP address and your internal IP address (probably entire network) is different. Thats why I was talking about MIPS (MappedIP) and VIPS (VirtualIP) earlier.
post #16 of 33 (permalink) Old 07-18-2006, 01:02 PM
VTwin FTW!
ChicagoFactory's Avatar
Years Riding: 20
After much research on this subject and talking with an expert on this stuff, he said GoToMyPC is the safest way to go, so that's what I did. I have a lot of important info on my home PC, and I don't want to take a chance with security. I've been using it for 3 years now and it works great. If you pay for a year up front instead of monthly, it's cheaper.
ChicagoFactory is offline
post #17 of 33 (permalink) Old 07-18-2006, 01:09 PM Thread Starter
Sportbike: ZX9R
Garage
after reading all this , I may try to get my boss to spring for it
First Place Oils
post #18 of 33 (permalink) Old 07-18-2006, 01:14 PM
mthal is offline
post #19 of 33 (permalink) Old 07-18-2006, 01:20 PM Thread Starter
Sportbike: ZX9R
Garage
Originally Posted by mthal
how secure is it?
First Place Oils
post #20 of 33 (permalink) Old 07-18-2006, 01:31 PM
how secure is it?
You can use encryption plugins and MS logon authentication.
mthal is offline
post #21 of 33 (permalink) Old 07-18-2006, 01:33 PM
The Victim Newbie
clearwaterms's Avatar
Sportbike: 2007 mountain bike
Years Riding: just started
How you found us: svrider.com
I second a VPN connection into your network and then a RDP / VNC as both are free. If you don't have VPN then you will need to consider other options, but VPN should defeat the firewall, as everything is sent encrypted over that VPN tunnel
<-- Chris
clearwaterms is offline
post #22 of 33 (permalink) Old 07-18-2006, 01:42 PM
The extra paranoid run vnc through a ssh tunnel over the VPN connection
post #23 of 33 (permalink) Old 07-18-2006, 01:47 PM
Yep, and not the MS VPN solution either.
post #24 of 33 (permalink) Old 07-18-2006, 01:50 PM
Might run a little slow though?
post #25 of 33 (permalink) Old 07-18-2006, 01:56 PM
I am running similar to this, and on a broadband connection, very close to LAN type speeds. Its even not too bad using verizon wireless broadband on my laptop.
post #26 of 33 (permalink) Old 07-18-2006, 02:16 PM
I run that way all the time. It's only slow if you have a cheesy underpowered cpu in the mix anywhere.
post #27 of 33 (permalink) Old 07-19-2006, 10:12 AM
Ooooooooohhh!!!!
blackrose613's Avatar
Sportbike: Katana 750
Years Riding: 30 years
How you found us: google search
Send a message via Yahoo to blackrose613
that ultraVNC is pretty nice. I just downloaded it. has quite a few nice features.
Now for my question. I am trying to use this to actually go the opposite way. I am trying to acces my home PC from work. I cant use RDC since they have shut down those ports.
Is there a way that I can list out the ports that they have left open? in other words, how can i find out what ports they have left open thru the firewall?
_________
Chrys
____________________
2000 Suzuki Katana 750
Lol I am no pimp. I am married and have no game.
blackrose613 is offline
post #28 of 33 (permalink) Old 07-19-2006, 11:40 AM
You can probably find some site online that will run a port scan for you.
post #29 of 33 (permalink) Old 07-19-2006, 11:42 AM
Here ya go, I trust this guy. He makes some great products and runs a good security podcast as well...
https://www.grc.com/x/ne.dll?bh0bkyd2
post #30 of 33 (permalink) Old 07-19-2006, 01:10 PM
Ooooooooohhh!!!!
well... that did not work! LOL
"The administrators of this network detected the scans and probings of this ShieldsUP! site and have asked us to please desist from any future contact with systems within their network. Thus, we are unable to provide you with any additional information. "
God i hate this company!!
_________
Chrys
