Windows won't start - Chicagoland Sportbikes
post #1 of 14 (permalink) Old 03-12-2007, 01:05 PM Thread Starter
Windows won't start
I have a Sony Vaio laptop. It gets stuck on the Windows XP startup screen, times out, and gives me this message:
A problem has been detected and windows has been shut down to prevent damage to your computer. The problem seems to be caused by the following file: partmgr.sys
I ran a couple spyware programs the last time it was used. Found very little problems, and ok'd deletions. Don't know if that had something to do with the current problem or not.
It gives me the option to start in safe mode, and I cannot get that to work either.
Any suggestions? or even where I should go to get it fixed, if it is fixable?
Brian is offline
post #2 of 14 (permalink) Old 03-12-2007, 01:10 PM
last known good configuration.
post #3 of 14 (permalink) Old 03-12-2007, 01:10 PM
Do you have an XP CD? If so, you can't boot to that and hit R for recovery mode and then type in the administrator password and try to run a repair.
Also, I have a CD that we can boot it to and then we can copy stuff you need to keep from the hard drive and onto a memory stick. Then you can reinstall the OS and restore your files. I can't let you have the CD, but I can help you use it.
Do you have any system recovery CDs that came with the laptop?
post #4 of 14 (permalink) Old 03-12-2007, 01:11 PM
last known good is a crap shoot.
uniball is offline
post #5 of 14 (permalink) Old 03-12-2007, 01:27 PM Thread Starter
I don't
Brian is offline
post #6 of 14 (permalink) Old 03-12-2007, 01:30 PM Thread Starter
Aside from some replaceable porn, there are not any files I need off it. I was using it for convenience, and backing up files I have on my desktop.
Brian is offline
post #7 of 14 (permalink) Old 03-12-2007, 01:30 PM
leavundst's Avatar
Years Riding: 9
How you found us: Jesus
Will it start in Safe Mode?
leavundst is offline
post #8 of 14 (permalink) Old 03-12-2007, 01:31 PM
Curb your dogma.
Phily-D's Avatar
Sportbike: another Honda:)
How you found us: BusaDave
+1 I have rarely seen this work. the recovery console option with the Windows install CD is a good start. Do a chkdsk /r when you log on to the install. See how that goes and report back.
"Cr-Cr-Cr-Crambone!!"
Phily-D is offline
post #9 of 14 (permalink) Old 03-12-2007, 01:32 PM Thread Starter
No. It scrolls a bunch of file locations on the screen, and then freezes.
Brian is offline
post #10 of 14 (permalink) Old 03-12-2007, 01:33 PM
Curb your dogma.
Phily-D's Avatar
Originally Posted by Brian View Post
I don't
Do you have a utility partition available from the OEM OS install?
Phily-D is offline
post #11 of 14 (permalink) Old 03-12-2007, 01:33 PM
leavundst's Avatar
Years Riding: 9
actually either way, the easiest thing would be to do a repair install of windows xp. You just need to borrow a cd from someone. If are near Northbrook or Mundelein I can loan you one. The nice thing about repair install is you won't loose anything.
post #12 of 14 (permalink) Old 03-12-2007, 01:35 PM
reload
post #13 of 14 (permalink) Old 03-12-2007, 02:11 PM
Do this. Boot to the XP cd and go into recovery mode. Run chkdsk /r as suggested. There may be some corrputed files that can be fixed.
How to use the Recovery Console
You can enable and disable services, format drives, read and write data on a local drive (including drives that are formatted to use the NTFS file system), and perform many other administrative tasks. The Recovery Console is particularly useful if you have to repair your computer by copying a file from a disk or CD-ROM to your hard disk, or if you have to reconfigure a service that is preventing your computer from starting correctly.
If you cannot start your computer, you can run the Recovery Console from the Microsoft Windows XP startup disks or the Windows XP CD-ROM. This article describes how to perform this task.
After Windows XP is installed on your computer, to start the computer and use the Recovery Console you require the Windows XP startup disks or the Windows XP CD-ROM.
For more information about how to create Startup disks for Windows XP (they are not included with Windows XP), click the following article number to view the article in the Microsoft Knowledge Base:
310994 (http://support.microsoft.com/kb/310994/) Obtaining Windows XP Setup boot disks
Note To start the computer from the Windows XP CD-ROM, you must configure the basic input/output system (BIOS) of the computer to start from your CD-ROM drive.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps: 1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Back to the top
How to use the Recovery Console command prompt
When you use the Recovery Console, you are working at a special command prompt instead of the ordinary Windows command prompt. The Recovery Console has its own command interpreter. To enter this command interpreter, you are prompted by Recovery Console to type the local Administrator password.
When the Recovery Console starts, you can press F6 to install a third-party SCSI or RAID driver, in case you need such a driver to access the hard disk. This prompt works the same as it does during installation of the operating system.
The Recovery Console takes several seconds to start. When the Recovery Console menu appears, a numbered list of the Windows installations on the computer appears. (Generally, only c:\Windows exists.) Press a number before you press ENTER, even when only one entry appears. If you press ENTER without selecting a number, the computer restarts and begins the process again.
When you see the prompt for %SystemRoot% (generally C:\Windows), you can start using the available commands for the Recovery Console.
Back to the top
Command actions
The following list describes the available commands for the Recovery Console: • Attrib changes attributes on one file or subdirectory.
• Batch executes commands that you specify in the text file, Inputfile. Outputfile holds the output of the commands. If you omit the Outputfile parameter, output appears on the screen.
• Bootcfg modifies the Boot.ini file for boot configuration and recovery.
• CD (Chdir) operates only in the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources.
• Chkdsk The /p switch runs Chkdsk even if the drive is not flagged as dirty. The /r switch locates bad sectors and recovers readable information. This switch implies /p. Chkdsk requires Autochk. Chkdsk automatically looks for Autochk.exe in the startup folder. If Chkdsk cannot find the file in the startup folder, it looks for the Windows 2000 Setup CD-ROM. If Chkdsk cannot find the installation CD-ROM, Chkdsk prompts the user for the location of Autochk.exe.
• Cls clears the screen.
• Copy copies one file to a target location. By default, the target cannot be removable media, and you cannot use wildcard characters. Copying a compressed file from the Windows 2000 Setup CD-ROM automatically decompresses the file.
• Del (Delete) deletes one file. Operates within the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources. By default, you cannot use wildcard characters.
• Dir displays a list of all files, including hidden and system files.
• Disable disables a Windows system service or driver. The variable service_or_driver is the name of the service or driver that you want to disable. When you use this command to disable a service, the command displays the service's original startup type before it changes the type to SERVICE_DISABLED. Note the original startup type so that you can use the enable command to restart the service.
• Diskpart manages partitions on hard disk volumes. The /add option creates a new partition. The /delete option deletes an existing partition. The variable device is the device name for a new partition (such as \device\harddisk0). The variable drive is the drive letter for a partition that you are deleting (for example, D). Partition is the partition-based name for a partition that you are deleting, (for example: \device\harddisk0\partition1) and can be used instead of the drive variable. The variable size is the size, in megabytes, of a new partition.
• Enable enables a Windows system service or driver. The variable service_or_driver is the name of the service or driver that you want to enable, and start_type is the startup type for an enabled service. The startup type uses one of the following formats:
SERVICE_BOOT_START
SERVICE_SYSTEM_START
SERVICE_AUTO_START
SERVICE_DEMAND_START
• Exit quits the Recovery Console, and then restarts the computer.
• Expand expands a compressed file. The variable source is the file that you want to expand. By default, you cannot use wildcard characters. The variable destination is the directory for the new file. By default, the destination cannot be removable media and cannot be read-only. You can use the attrib command to remove the read-only attribute from the destination directory. The option /f:filespec is required if the source contains more than one file. This option permits wildcard characters. The /y switch disables the overwrite confirmation prompt. The /d switch specifies that the files will not be expanded and displays a directory of the files in the source.
• Fixboot writes a new startup sector on the system partition.
• Fixmbr repairs the startup partition's master boot code. The variable device is an optional name that specifies the device that requires a new Master Boot Record. Omit this variable when the target is the startup device.
• Format formats a disk. The /q switch performs a quick format. The /fs switch specifies the file system.
• Help If you do not use the command variable to specify a command, help lists all the commands that the Recovery Console supports.
• Listsvc displays all available services and drivers on the computer.
• Logon displays detected installations of Windows and requests the local Administrator password for those installations. Use this command to move to another installation or subdirectory.
• Map displays currently active device mappings. Include the arc option to specify the use of Advanced RISC Computing (ARC) paths (the format for Boot.ini) instead of Windows device paths.
• MD (Mkdir) operates only within the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources.
• More/Type displays the specified text file on screen.
• Rd (Rmdir) operates only within the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources.
• Ren (Rename) operates only within the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources. You cannot specify a new drive or path as the target.
• Set displays and sets the Recovery Console environment variables.
• Systemroot sets the current directory to %SystemRoot%.
Back to the top
Recovery Console rules
Several environment rules are in effect while you are working in the Recovery Console. Type set to see the current environment. By default, these are the rules: • AllowAllPaths = FALSE prevents access to directories and subdirectories outside the system installation that you selected when you entered the Recovery Console.
• AllowRemovableMedia = FALSE prevents access to removable media as a target for copied files.
• AllowWildCards = FALSE prevents wildcard support for commands such as copy and del.
• NoCopyPrompt = FALSE means that you are prompted by the Recovery Console for confirmation when overwriting an existing file.
post #14 of 14 (permalink) Old 03-12-2007, 09:12 PM
RSV4win's Avatar
Sportbike: 2002
do some google searching. type in partmgr.sys
looks like someone with same laptop had same problem.
http://techrepublic.com.com/5208-111...hreadID=181956
RSV4win is offline
