Mini rant on coding. - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 03-30-2007, 04:46 PM Thread Starter
Sorry this is one of those times I gotta share and there's gotta be a coder or developer here that's gone through this more than once Now I've written a fair amount of code...SQL, VB, C++ and developed some programs that I'm proud of. Usually this happens without a hitch. But then there are times when you need to create a such a simple little thing that turns into more lines than you expected and a whole helluva lot more thought than ever imagined. The task? Look at a field. If there are any lower case letters in it then consider it a failure...otherwise it passes. Simple I figured...just see if "Ucase(field) = field" and presto in one line...not so fast. The friggen code to do this simple task?
stringvar x;
numbervar i;
stringvar z;
numbervar strLen;
global stringvar UCaseCheck := 'Pass';
strLen := len({Command.Invoice Number});
x := totext({Command.Invoice Number});
z := totext({Command.Invoice Number});
ucase(x);
For i := 1 to strLen Do
Local NumberVar charPos := i;
if AscW(x[charPos]) <> AscW(z[charPos]) then UCaseCheck := 'Fail';
UCaseCheck;
post #2 of 9 (permalink) Old 03-30-2007, 05:23 PM
SV650N
crashomon's Avatar
Sportbike: 2005 SV650SN
Years Riding: Since 1980
How you found us: craigslist
Time to start using PHP!
crashomon is offline
post #3 of 9 (permalink) Old 03-30-2007, 05:32 PM
Doesn't your string start at position [0] and not [1] ?
...at least in C it does... in which case 'i' should initialize at 0
What lang is that?
post #4 of 9 (permalink) Old 03-30-2007, 05:46 PM
[Online]
Fracker's Avatar
Years Riding: Since 2004
It looks like Crystal Reports script. This is a fucking abomination.
+1 on what Arch said - I don't remember how it is in Crystal Reports, but it can be 0-based string.
Wait, why do you even compare them letter by letter? Why doesn't "Ucase(field) = field" work?
- Stas
Fracker is offline
post #5 of 9 (permalink) Old 03-30-2007, 10:56 PM Thread Starter
The language is Crystal syntax of VB6. You can write one of a few languages. If things like DIM is your cup'o'tea then it'll accept it too. i = 1 works for Crystal Reports. Don't ask me why, but yea everywhere else it's been 0. 0 works too though.
As for comparing straight "ucase(field) = field". That does not work because crystal will not tell a difference between caps vs not except in certain instances like 'instr', 'filter', etc... So in crystal syntax...'AAA' = 'aaa' is true including any other combo's 'AaA' = 'aAA...etc.
This meant that I had to convert to ascii and compare the numbers. However AscW only takes the first letter, so in order to check the entire string you gotta do the loop.
post #6 of 9 (permalink) Old 03-30-2007, 11:50 PM
I assume you tried:
x := UpperCase(totext({Command.Invoice Number}));
y := totext({Command.Invoice Number});
if x<>y then UCaseCheck := 'Fail';
post #7 of 9 (permalink) Old 03-31-2007, 12:38 AM Thread Starter
Yup. Although that would fail based on the first test I did which was:
if 'AAA' = 'aaa' then BAD else GOOD. By the nature of Crystal I guess it never compares case unless you tell it to.
But good that no one just whipped out an answer in 3 seconds of some magical function that I never heard of Makes me feel not as dumb for taking an hour to figure out that the others fail, and then to write these few lines
post #8 of 9 (permalink) Old 03-31-2007, 01:04 AM
Even tried compareStr() ? basically, like strcmp() and it's supposed to be case sensitive.
post #9 of 9 (permalink) Old 04-01-2007, 01:15 PM
Evertime I see code I can't help but think about maintaining code. If you haven't read this book already, I highly recommend it as one of the best resources available on writing quality, efficient and maintainable code.
Code Complete - Steve McConnell
P.S. - I don't write or even look at code very often anymore. I became a project manager partly because my code was usually ugly and a PITA to maintain by anyone other than me. But I am always on my Tech Leads to include more than functional checks in their code reviews.
flinchy is offline
