my clock keeps acting up! "Windows XP Pro" - Chicagoland Sportbikes
post #1 of 20 (permalink) Old 05-15-2007, 10:25 AM Thread Starter
any idea why it keeps doing this? once in a while and its almost happening once a month, i keep having to set the clock forward and hour or so on my PC.
post #2 of 20 (permalink) Old 05-15-2007, 10:27 AM
RSV4win's Avatar
Sportbike: 2002
Try a $2 battery first. if not you can find an atomic clock program to keep it updated.
RSV4win is offline
post #3 of 20 (permalink) Old 05-15-2007, 10:27 AM
See if the daylight savings box is checked. Mine did that, unchecked it and its fine.
post #4 of 20 (permalink) Old 05-15-2007, 10:37 AM Thread Starter
my date and time properties shows
that its "CHECKED" to synchronize with an internet time server: time.windows.com
and it shows the next time its going to synchronize is on 5/21/07 at 10:48pm
wtf??
i dont see nothing for daylight savings time under the date and time property's
post #5 of 20 (permalink) Old 05-15-2007, 10:41 AM
Simplest of things
This is the best tip so far. Usually on the mobo the battery is dying (people don't realize it's a battery there like your watch) and it's nothing to replace it.
If that doesn't do it then it's like Jughead posted, try a atomic clock program. I'm using one at home and it's never given me problems.
If your copy of XP is legal try updating drivers and such. Since daylight's savings time wasn't on the usual day a lot of things have been thrown off.
Loki_D_Wolf is offline
post #6 of 20 (permalink) Old 05-15-2007, 10:42 AM Thread Starter
so try changing the internal battery in my PC 1st and see if the problem goes away huh?
post #7 of 20 (permalink) Old 05-15-2007, 10:47 AM
Time Goes By So Slowly
I would. Be careful not to bend or break anything and stay grounded by touching the frame or some type of metal (I usually am leaning my arm on the cover) and yeah, pop out the old battery and put in a new one. I've done it once a while back when my clock kept changing times and realized that's what it was.
check out this site too for some helpful things in the future:
tweakxp.com
post #8 of 20 (permalink) Old 05-15-2007, 10:51 AM
Bad MB battery would show itself by losing BIOS information.
post #9 of 20 (permalink) Old 05-15-2007, 11:59 AM
hellion29's Avatar
Sportbike: Suzuki GSX-R750
Years Riding: I ride a tricycle
How you found us: Google!
+1 I'm calling that the xp fix to daylight savings time wasn't installed is all.
-Zach
http://www.myspace.com/zachreborn
PSN: reborn29
hellion29 is offline
post #10 of 20 (permalink) Old 05-15-2007, 12:00 PM
10001010000100010101111010
I didn't have that problem when I had to replace mine. Maybe I caught it in time.
post #11 of 20 (permalink) Old 05-15-2007, 01:25 PM
stuck in 6th gear
Ernie's Avatar
is your machine set to the correct timezone?
it sounds like everytime XP hits the ntp server to sync up that it's changing your time by 1 hr because you have an incorrect timezone set for your machine
Ernie is offline
post #12 of 20 (permalink) Old 05-15-2007, 01:28 PM Thread Starter
(GMT -6:00 central america)
post #13 of 20 (permalink) Old 05-15-2007, 01:29 PM
That isn't evident anymore like it was in the old days when you had to manaully set hard drive parameters in the BIOS. I doubt Ken has changed any non-default settings in the BIOS that aren't already PnP, so the clock is really the only indication of a failing battery.
How old is the computer? I haven't had to replace a BIOS battery in ages, they usually outlast my usage of the computer itself.
post #14 of 20 (permalink) Old 05-15-2007, 01:43 PM
Loki Gates
Ken, change the battery. Even if that's not the problem at least you can eliminate that as a cause.
post #15 of 20 (permalink) Old 05-15-2007, 02:03 PM
stuck in 6th gear
Ernie's Avatar
BZZT!
the battery keeps the time for the clock when it's not running on AC.
it's easier to take a meter to the battery and check for proper voltage than to just swap it outright.
if Ken's clock was off a few minutes then I would suspect a battery issue but he says it's off by 1 hour exactly so it would seem to be a software issue...
sounds like a daylight savings time issue to me too since you're always setting it ahead 1 hr.
is the date correct?
Ernie is offline
post #16 of 20 (permalink) Old 05-15-2007, 02:06 PM
Other side of the coin
Originally Posted by Ernie View Post
BZZT!
Ok, then he can do the other suggestions, update. lol Either that or get a free software program to keep up with the time. I'm using one because of the different day that was used this year. I'm using an atomic program so I don't have to worry about this crap again.
post #17 of 20 (permalink) Old 05-15-2007, 02:32 PM
I can never understand Ken's posts LOL
Ken are you saying that you have to randonly bump up the time as it's falling behind, or it's always 1 (or 2 or 3) hours off, but the minutes are correct?
Like I said, I rarely touch batteries anymore. It's either a DST setting, DST-realtaed patch issue (not updated) or you could be synching with a 'bad' server.
post #18 of 20 (permalink) Old 05-15-2007, 03:18 PM
Dude, its your time zone and/or the DST fix. Since when did you move to central america? LOL!
Cange it to "central time (US&Canada)"
Doh!
post #19 of 20 (permalink) Old 05-15-2007, 03:24 PM
stuck in 6th gear
Ernie's Avatar
lol, yeah Ken, you're one off in the timezone popup menu.
select the next one down. should be
(GMT-06:00) Central Time (US & Canada)
Ernie is offline
post #20 of 20 (permalink) Old 05-15-2007, 03:55 PM
I didn't even see this post.
Central America doesn't observe DST, so your clock will be off half of the year. Plus it wreaks havoc with your Outlook Calendar...
