High & Wet - Chicagoland Sportbikes
post #1 of 6 (permalink) Old 08-07-2007, 11:55 AM Thread Starter
OBAMA FTW!!!!1!
.:K2:.'s Avatar
High & Wet
WTF does that mean when a T1 circuit is High and Wet?
<---- Andy
Crashed Bike pictures:
.:K2:. is offline
post #2 of 6 (permalink) Old 08-07-2007, 11:57 AM
Sounds like my last girlfriend...
post #3 of 6 (permalink) Old 08-07-2007, 11:57 AM
i like them wet down below
post #4 of 6 (permalink) Old 08-07-2007, 11:59 AM Thread Starter
OBAMA FTW!!!!1!
.:K2:.'s Avatar
<---- Andy
.:K2:. is offline
post #5 of 6 (permalink) Old 08-07-2007, 12:07 PM Thread Starter
OBAMA FTW!!!!1!
.:K2:.'s Avatar
Found it
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Permanent Signal (PS) in US telephony jargon, or Permanent Loop in British usage, is a condition in which a POTS line is off-hook for an extended period of time. This is indicated in modern switches by the silent termination after the off hook tone times out and the telephone exchange computer puts the telephone line on its High & Wet list or Wetlist. In older switches, however, a Permanent Signal Holding Trunk (PSHT) would play either howler tone or high tone (which would subsequently bleed into adjacent lines via crosstalk). Howler tone is a tone of increasing intensity that is intended to alert telephone users to the fact that they have left the receiver off the hook.
Permanent signal can also describe the state of a trunk that is seized but has not been dialed upon, if it remains in a busy condition (sometimes alerting with reorder).
In most middle 20th century switching equipment, a permanent signal would tie up a junctor circuit, diminishing the ability of the switch to handle outgoing calls. When flooded cables or other conditions made this a real problem, switch staff would open the cable, or paper the off-normal contacts of the crossbar switch, or block the line relay from operating. These methods had the disadvantage of blocking all outgoing calls from that line until it was manually cleared. Manufacturers also sold devices that monitored the talk wires and held up the cutoff relay or crossbar hold magnet until the condition cleared. Some crossbar line circuit designs had a park condition allowing the line circuit itself to monitor the line.
Stored program control exchanges finally solved the problem, by setting a bit mask in the scanning program and running a low priority checking program against the wetlist. Depending on software version, a wetlisted line may also be in PLO or lockout state.
<---- Andy
.:K2:. is offline
post #6 of 6 (permalink) Old 08-07-2007, 12:14 PM
Terminating line is high and wet (battery and ground shorted) or high and dry (off hook for an extended period).
