10/100BaseT over Cat3 - Chicagoland Sportbikes
post #1 of 63 (permalink) Old 09-25-2007, 02:10 PM Thread Starter
Anyone do this over short distances, say 50 feet or so? I'm hoping to convert an existing Cat3 phone line(home run, not shared) to a data line. I'm concerned that the computers will autonegotiate to 100baseT and drop packets like mad. I'm sure at 10BaseT it'd be money but I doubt my router/PC will negotiate to that speed.
thoughts?
post #2 of 63 (permalink) Old 09-25-2007, 02:13 PM
-= OuterSpace =-
OldSkoolMC's Avatar
Sportbike: Yamaha YZ450
How you found us: Shizzle
Should be no problem with that short of a run. Turn off auto negotiate and test.
06 Kawasaki BruteForce 750i
09 Yamaha Raptor 700r
- Mike - OldSkool - MC -
OldSkoolMC is offline
post #3 of 63 (permalink) Old 09-25-2007, 02:15 PM
post #4 of 63 (permalink) Old 09-25-2007, 02:17 PM Thread Starter
For what it's worth the cabling visually looks like cat5 but I havent seen any markings on it to justify this, it's not some ancient crappy cat3 that many of you I'm sure have seen in your day. I'll probably punch it down rj45 and test it tonight.
post #5 of 63 (permalink) Old 09-25-2007, 02:17 PM
You are going to have to up the flux capacitor to 1.21 jigawatts for that to work. I'll check with Doc though.
post #6 of 63 (permalink) Old 09-25-2007, 02:18 PM
Why bother?
If its CAT5 that will be fine. CAT3 .... bleh
post #7 of 63 (permalink) Old 09-25-2007, 02:19 PM
-= OuterSpace =-
OldSkoolMC's Avatar
The difference is cat3 isn't twisted pair. So you may get dropped packets.... why not just pull a new cat5 line? I have a ton if you need some.
post #8 of 63 (permalink) Old 09-25-2007, 02:21 PM Thread Starter
Why bother?
good question, and I was sure it would come up.
I have DSL internet service at home, fed up to my office above my garage. From there it goes into my DLS modem and ultimately my router for my network(PC, laptop, test laptop, network printer).
The problem is I want to put my xbox360 on live and it's located at the furthest location from the router in the house(first floor, opposite end), a location I've never gotten good wireless signal at with laptops(I have no reason to think the wireless adapater for the xbox would be any better). If I move the router close to the xbox I need to then get internet back to the office. If I leave the router where it is I need to get wiring back to the xbox(next to impossible without drywall work).
oldskool, the cat3 run is 4pairs UTP. which is why I think I should be money. Hell it might be cat5 without markings.
post #9 of 63 (permalink) Old 09-25-2007, 02:23 PM
Put in another WAP.
post #10 of 63 (permalink) Old 09-25-2007, 02:25 PM Thread Starter
Put in another WAP.
i've considerd it, though if possible I like to minimize boxes around the house and possible points of failure.
post #11 of 63 (permalink) Old 09-25-2007, 02:25 PM
-= OuterSpace =-
OldSkoolMC's Avatar
yeah, it has pairs but they are not "twisted pairs". Hence the reason cross talk can happen on cat3.
Like I said, if you need some cat5 I have some just drive your ass out and I'll hook you up with some.
post #12 of 63 (permalink) Old 09-25-2007, 02:26 PM
Ninja Kick!
Insomniac's Avatar
Sportbike: 09 R6 09, RS125
Years Riding: Not enough
How you found us: Spongebob
I'm presuming you're planning on running it through a preexisting wall socket. Why not remove the current faceplate, replace it with a dual and run the cable. No drywall work required.
Insomniac is offline
post #13 of 63 (permalink) Old 09-25-2007, 02:29 PM Thread Starter
I just said it's UTP numbnuts!! haha, I've looked at it and visually it's just like cat5. 4 twisted pairs.
Insomniac, I cannot pull another run to this location as it does not follow a direct path nor is it in conduit.
post #14 of 63 (permalink) Old 09-25-2007, 02:32 PM
-= OuterSpace =-
OldSkoolMC's Avatar
Doh! didn't see the UTP part.
I said before in such a short run it may work.
Other option is 360 wireless card and this:
http://www.circuitcity.com/ccd/produ...T&cm_keycode=4
post #15 of 63 (permalink) Old 09-25-2007, 02:34 PM
Consider the fish-tape trick.. just duct tape the end of a new cable to the existing and pull it through from one end
On a serious note though, it you must, just force your network cards to be 10-T or simply just jack the end near your net connection into a cheap ass $8.00 10baseT hub, then cross connect/uplink it into your other stuff.. It will force the other end to 10T
post #16 of 63 (permalink) Old 09-25-2007, 02:35 PM
I hope it then doesnt connect to your computer the the UBS port, ethernet is a better connection for all DLS modems.... (smartass off)
good luck, and GOIOd choice to run wire, xbox with wireless still has too much latency for me.
post #17 of 63 (permalink) Old 09-25-2007, 02:39 PM Thread Starter
to answer questions.
vcook does not use usb for internet.
the existing run is not direct enough to do the tape and pull method, nor fishing.
old crappy 10baseT hub is a funny and realistic option to force 10baseT negotiation.
thanks guys
post #18 of 63 (permalink) Old 09-25-2007, 02:48 PM
yo quiero su taco
whiteSeatEnvy's Avatar
slide the fork tubes up to compensate.
whiteSeatEnvy is offline
post #19 of 63 (permalink) Old 09-25-2007, 04:54 PM
seriously though, do you have a path we can use to get to the basement? your office is over the garage correct? lets run a cat 5 down the wall and into the garage, then we can run it through the garage, and into the basement, once into the basement we run up in the joists all the way to your family room and pop up out through the wall via a jack. sweet and simple.
Need cable and connectors? I got shitloads.
post #20 of 63 (permalink) Old 09-25-2007, 04:59 PM
I was just about to suggest that, or with a slight twist mount the router in the basnement joist for more symmetrical coverage. I cannot believe you've gone this long without a strong signal in the main room of the house. This what I did at my old place in the front of the house and had reception on the back deck.
Warp speed.
post #21 of 63 (permalink) Old 09-25-2007, 05:00 PM
Funny how he has time to mess with all this shit, but cant get his damn carb fixed.
post #22 of 63 (permalink) Old 09-25-2007, 05:02 PM
He's off the hook for this weekend, but its on again for next.
post #23 of 63 (permalink) Old 09-25-2007, 05:03 PM
oh yes, it is definitely on again for next.
post #24 of 63 (permalink) Old 09-25-2007, 05:07 PM
With or without Crhis let's plan a garage night next week to fix his bike.
post #25 of 63 (permalink) Old 09-25-2007, 05:09 PM
I'm thinking that might be necessary.
post #26 of 63 (permalink) Old 09-25-2007, 06:55 PM Thread Starter
the plan is to move the router to the basement, thats why i'm jumping through hoops. stay tuned.
post #27 of 63 (permalink) Old 09-25-2007, 06:58 PM Thread Starter
current speed, which is teh suk. i should call on this.
post #28 of 63 (permalink) Old 09-25-2007, 07:23 PM
i would i am a touch higher then that on DSL
post #29 of 63 (permalink) Old 09-25-2007, 07:26 PM
Thats cause DSL sucks
post #30 of 63 (permalink) Old 09-25-2007, 07:27 PM
9178 / 1424
