brake fade, GSXR master cylinders suck that bad? - Chicagoland Sportbikes
post #1 of 43 (permalink) Old 09-05-2011, 09:16 PM Thread Starter
NickIF's Avatar
Sportbike: FJR1300
Was working on late braking today and was getting some nasty fade...
My setup:
'04 GSXR 600
Brakes bled at the track with RBF600
SBS pads with a little less than 50% left
stainless lines
The only thing I can think, and what I've heard (possibly from a GSXR hater) is that the master cylinders notoriously suck? substitute?
NickIF is offline
post #2 of 43 (permalink) Old 09-05-2011, 09:40 PM
Nexus's Avatar
Sportbike: nada
Years Riding: 18
How you found us: No idea
I had an Accossato from Kevin at Safety First Racing on my 07GSXR600 and it was 100x better
Nexus is offline
post #3 of 43 (permalink) Old 09-05-2011, 09:50 PM
I do think the master sucks, but I hear the calipers aren't the greatest either. After about a day, I get a squishy feel on the lever (Accossato), but the brakes are still strong.
post #4 of 43 (permalink) Old 09-05-2011, 10:06 PM Thread Starter
NickIF's Avatar
Sportbike: FJR1300
Damn... I can't believe they suck that bad. I'm going to try changing out the pads (since I have a new set sitting here) just to see if that helps at all. The first session after the bleed they were good. Then they went to shit again. The lever pulls back now (cold) to less than 1.5" from the clip-on and that's with it set on 1. Just barely off my knuckles.
NickIF is offline
post #5 of 43 (permalink) Old 09-05-2011, 10:10 PM
I don't know...
Germany's Avatar
YES...
Brembo or Accossato, the later is pretty much the same, just a few $ cheaper...
Edit: I just remember that somone said the newer R6 masters are pretty good, but I'm not sure...
#19
Germany is offline
post #6 of 43 (permalink) Old 09-05-2011, 10:23 PM
I have an Accossato master, Vesrah RJL pads and Galfer wave rotors. They all improve brake performance, but the lever still feels soft on the initial pull.
post #7 of 43 (permalink) Old 09-05-2011, 10:26 PM
Nexus's Avatar
Sportbike: nada
Years Riding: 18
Another route might be the 2011 GSXR master and calipers. The ones you have and prior models use the Tokico. For 2011 they changed over to some pretty Brembos...
"Braking is now handled by Brembo radial-mount four-piston calipers biting on larger 280mm discs (up from the 276.8mm units of before), with the rear disc dropping in size from 188mm to 186mm."
Now just wait till winter and see if anyone is parting a bike out
Damn I want this 600 now...white rims!!
Nexus is offline
post #8 of 43 (permalink) Old 09-05-2011, 10:33 PM
I know of one that losses lever after about a week of use.Bleed several times.
Pumps up good with no leaks I'm not sure what to fix.
post #9 of 43 (permalink) Old 09-05-2011, 10:52 PM
Addicted
eE jeremy's Avatar
Ditch those pads for some Vesrah's. 50% of the pad remaining means they are half as thick meaning they only have half the material to dissipate heat, therefore they will heat up and fade. Plus they aren't my favorite pad to begin with.
The master could very will be going too, when the seals start to go they can lose pressure and cause some braking issues. I found when mine failed I could only do about 3/4 of a session before I'd have to pull off and pump the lever to build pressure again. I got the brembo 19x18 and love it.
Shitty Pass Racing #513
eE jeremy is offline
post #10 of 43 (permalink) Old 09-05-2011, 10:53 PM
mc seals gus, check the bore for scoring as well
what sbs pads are you using and at what pace?
i was using the sbs sintered pads and was seeing short life and rapid fade through a session/race, i switched to the dual carbons and after gettign used to their initial characteristics like them alot, no fade anymore and improved wear life. we'll see how long they last at the end of this season...
also just because you just bled them doesnt guarantee that there isnt a small bubble still in there.
post #11 of 43 (permalink) Old 09-05-2011, 11:04 PM Thread Starter
NickIF's Avatar
Sportbike: FJR1300
I believe they are dual carbons... I'm running a "spirited" intermediate/slow advanced pace. Plenty of traffic out there today (and red flags) to really get moving.
Brakes were first bled with a mighty vac, (at calipers and master cylinder) then by hand with the ziptie trick tapping/shaking the lines, MC, etc. to try and get any lingering bubbles out. I'm fairly confident there is no air in the lines. Really not looking to spend $600+ on brembos...
Does anyone else know about the R6 mastercylinders? Might have a line on an '06
NickIF is offline
post #12 of 43 (permalink) Old 09-05-2011, 11:06 PM
Safety First's Avatar
The gixxer masters suck....even on the 2011's
Kevin Hanson
Safety First Racing
Louisville, KY
[email protected]
Safety First is offline
post #13 of 43 (permalink) Old 09-05-2011, 11:12 PM Thread Starter
NickIF's Avatar
Sportbike: FJR1300
I guess this is a starting point then before I do calipers/rotors? Does anyone know where I can get one locally for a decent price?
http://www.motosport.com/motorcycle/...=badger-street
NickIF is offline
post #14 of 43 (permalink) Old 09-05-2011, 11:21 PM
Nexus's Avatar
Sportbike: nada
Years Riding: 18
How about $100 cheaper w/ free SS lines and a tshirt if you get an Accossato?
http://www.safetyfirstracing.com/Acc...ver_p_170.html
Not as well known in the US as Brembo, but a number of top level peeps in the AMA on Superbike and 600s are running them.
Nexus is offline
post #15 of 43 (permalink) Old 09-05-2011, 11:34 PM
I'll have him order all the MC parts.
Thanks
post #16 of 43 (permalink) Old 09-05-2011, 11:36 PM Thread Starter
NickIF's Avatar
Sportbike: FJR1300
Hmmm... I'd need to get it by friday.
NickIF is offline
post #17 of 43 (permalink) Old 09-05-2011, 11:51 PM
im runnign the same pads with about the same to less thickness left on them and they are not your problem. i got fade this past sat but it was due entirely to old fluid in the system, i bled it all out and the brakes were back to 100% of what they should be, im running a mid lower A pace so were seeing similar pad usage, the mc is a known weak point as others have said and its something i keep a close eye on for any sign of failure, I hope to get a aftermarket mc this winter along wth a laundry list of other items for the bike
post #18 of 43 (permalink) Old 09-06-2011, 02:24 AM
thin pads transfer more heat to the fluid... fyi.
post #19 of 43 (permalink) Old 09-06-2011, 07:03 AM
I don't know...
Germany's Avatar
... who needs brakes? They just slow you down...
get a new Master and I bet it will be 100 times better.
#19
Germany is offline
post #20 of 43 (permalink) Old 09-06-2011, 07:19 AM
It's the master Nick ..... I went through the same deal with my 04.
Pad's helped, bigger rotors helped, but what got them consistent was a Brembo.
post #21 of 43 (permalink) Old 09-06-2011, 07:35 AM
alocker's Avatar
Sportbike: 2007 GSXR 1000
Years Riding: .05 Years
How you found us: RAT
The R6 master helped but did not completely cure my mushy lever. Fresh fluid has been the only solution. This means a freshly cracked brake fluid bottle also, not something that has been in the hot garage for a few months.
_________________
CCS AM 454
alocker is offline
post #22 of 43 (permalink) Old 09-06-2011, 08:06 AM
This, when over the same thing with my 05 600.
post #23 of 43 (permalink) Old 09-06-2011, 08:53 AM
I went from bleeding twice a weekend to bleeding twice a season.
post #24 of 43 (permalink) Old 09-06-2011, 08:57 AM Thread Starter
NickIF's Avatar
Sportbike: FJR1300
sounds good, im going to try and order one today
NickIF is offline
post #25 of 43 (permalink) Old 09-06-2011, 09:46 AM
Nick...sent you a PM...you'll have it the next day.
Kevin Hanson
Safety First Racing
Louisville, KY
[email protected]
post #26 of 43 (permalink) Old 09-06-2011, 11:23 AM
Registered Loser
Otis's Avatar
Sportbike: 06 gsxr 1k
How you found us: i forgot
a little bit off topic,
but i got me some of those vesrah XX pads we were talking about...
HOLY HAND OF GOD brake pads dude !!!
i was runnin RJL's before but these are insane.
Otis is offline
post #27 of 43 (permalink) Old 09-06-2011, 11:35 AM
Have a pro bleed them/check them, my calipers are stock, brembo master, superbike lines, vesrah pads and two finger full braking throughout the weekend.......you may have a problem: moisture, air etc.....
post #28 of 43 (permalink) Old 09-06-2011, 11:41 AM
Trust me...the masters suck.
Suzuki wouldn't listen and put Brembo calipers on the new bike and the problem is still the same. Ask any other AMA team that is racing them if you don't want to believe me.
Kevin Hanson
Safety First Racing
Louisville, KY
[email protected]
post #29 of 43 (permalink) Old 09-06-2011, 12:56 PM
Ride Naked
mac11's Avatar
Sportbike: z1000
Semi-related to this topic, how is the factory kawi zx6 master in relation? I'm doing a brake upgrade on my bike.
mac11 is offline
post #30 of 43 (permalink) Old 09-06-2011, 01:23 PM Thread Starter
NickIF's Avatar
Sportbike: FJR1300
ordered!
NickIF is offline
