tips on drilling bolts for safety wire? - Chicagoland Sportbikes
post #1 of 28 (permalink) Old 05-19-2004, 09:25 AM Thread Starter
tips, suggestions, bit types, bit sizes?
anyone got suggestions?
post #2 of 28 (permalink) Old 05-19-2004, 09:28 AM
Human lawn dart
rdrash's Avatar
How you found us: I know all
Drill press, Don't force the bit down and take your time. Practice on a bolt or something laying around the house.
MotoGP 200 mph no roll cage
NESBA # 599
rdrash is offline
post #3 of 28 (permalink) Old 05-19-2004, 09:30 AM
Drill press and buy a bunch of bits
post #4 of 28 (permalink) Old 05-19-2004, 09:31 AM
Grasshopper
Guest
Posts: n/a
I made this aluminum block that has different size thread pitches tapped in it. I screw the desired bolts in the block then put the block in the vise to drill them out. I use a hand drill.
Not sure about exact bit sizes or types. I just use what I have.
post #5 of 28 (permalink) Old 05-19-2004, 09:39 AM
BEER!
Grover's Avatar
JimGoFast said you can buy predrilled oil plugs Should be available for the Gixxers.
NESBA/CCS #142
AIM: GroverSV650S
Dirtbikes are not submarines
Grover is offline
post #6 of 28 (permalink) Old 05-19-2004, 09:44 AM Thread Starter
they arent cheap though, and i want to do more than just my drain plug.
post #7 of 28 (permalink) Old 05-19-2004, 09:57 AM
I'm always learning......
SloRoll's Avatar
How you found us: GPS
I have jigs that the nuts or bolts fit into and have a hole drilled where the bit fits in and is held in place while the piece is being drilled out.
In the absence of a jig, I would get some new bits with the titanium nitride coating to use. Use a drill press with a vice if you can. Press lightly, start slowly, use a light oil to cool.
When drilling the threaded portion of a bolt, you can easily make a jig by drilling through a nut on the first pass then use that nut for your jig on the subsequent bolts.
SloRoll is offline
post #8 of 28 (permalink) Old 05-19-2004, 09:58 AM
Where's my dam safety wire Chris?
post #9 of 28 (permalink) Old 05-19-2004, 10:00 AM
easy .....they sent me the last spool and yours has been on back order.
post #10 of 28 (permalink) Old 05-19-2004, 10:02 AM
cook, i got a drill press if you wanna come by one day with the bike, just bring some wire and saftey wire plyers
post #11 of 28 (permalink) Old 05-19-2004, 10:09 AM
the cheap way it to mark the bolt, pull it off, and hold it with vise-grips while you drill. Use small titanium bits, oil, and drill slowly.
post #12 of 28 (permalink) Old 05-19-2004, 10:25 AM
Grasshopper
Guest
Posts: n/a
Be careful you don't damage the threads on the bolt using this method. Thats why I made the aluminum block. It's way easier to hold on to the bolt. If you have a tap set this works pretty well.
I bought a cheap tap set at Menards for 25 bucks. And then I found a block of billet aluminum to tap into. Works good.
All I did was copy a part I saw in the LP USA parts catalogue. SHHHHHH! Don't tell anyone
post #13 of 28 (permalink) Old 05-19-2004, 10:30 AM
It'd be really trick if you milled the block on an angle so it would hold the bolt at an angle in the vise
post #14 of 28 (permalink) Old 05-19-2004, 10:34 AM Thread Starter
ok, what kind of oil should i use for cooling while drilling? I have access to a small vice and drill press.
post #15 of 28 (permalink) Old 05-19-2004, 10:37 AM
Doc
Doc's Avatar
Sportbike: 2006 Lemond Zurich
Years Riding: since the age of 4
How you found us: SBN...back in the day!
Send a message via AIM to Doc
I just used a little motor oil.
Doc
2006 Lemond Zurich
"A man who dares to waste an hour of life has not discovered the value of life."-Darwin
Doc is offline
post #16 of 28 (permalink) Old 05-19-2004, 10:42 AM
Grasshopper
Guest
Posts: n/a
The special patented "Evil Monkey Racing Oil" wont work for ya?
post #17 of 28 (permalink) Old 05-19-2004, 11:10 AM
Chris,
Nick's trick with the aluminium bolt will work, but it's too much work, I just use a block of hardwood, which I have always laying around, I also have a drill press vise. I don't know if your closer to Ken's place or my place, your welcome to use my drill press and vise.
Rick
Nick,
Dude Harbor Freight tools have the tap and die sets for $15, I now own both metric and sae
Rick
post #18 of 28 (permalink) Old 05-19-2004, 11:12 AM
DUUUUDE,
I don't grab the threads!!!!!! Grab the flats, drill, turn and drill to meet the other hole.
post #19 of 28 (permalink) Old 05-19-2004, 11:14 AM
Grasshopper
Guest
Posts: n/a
DUUUUDE,
10-4
post #20 of 28 (permalink) Old 05-19-2004, 11:29 AM Thread Starter
what do you guys think, do you generally go through the middle or do the corners? corners seems like a better route but might be more work.
post #21 of 28 (permalink) Old 05-19-2004, 11:31 AM
I like around the corner since it causes tension in one direction, but anything holding it in place is good.
post #22 of 28 (permalink) Old 05-19-2004, 11:33 AM
Let me know when you get to be an expert in all this Chris... then you can do mine for me!
post #23 of 28 (permalink) Old 05-19-2004, 11:35 AM
Do the corners if you a glutton for punishment I always do the middle, dimple it first, then drill away, I always use a spray cutting lubricants. If your going to do the corner, use a small triangle mill file, put a small notch in it, then your punch won't skate all over, dimple it and drill way, then if you have any burrs, carefully remove them with a mill file, one or two stroke should do the trick.
post #24 of 28 (permalink) Old 05-19-2004, 11:40 AM
SloRoll's Avatar
You can still put the proper tension on the bolt if you go through the center. You just have to use the wire the correct way and make sure it wraps around the head of the bolt and pulls in the proper direction.
SloRoll is offline
post #25 of 28 (permalink) Old 05-19-2004, 11:43 AM Thread Starter
HF was backordered then shipped me the wrong damn part. i just got off the phone with them, they are shipping me the correct stuff now. Should be here soon.
post #26 of 28 (permalink) Old 05-19-2004, 11:49 AM
You'll have to 'splain it to me sometime, when I do that they tend to pop over the top of the head.
post #27 of 28 (permalink) Old 05-19-2004, 12:26 PM
SloRoll's Avatar
I'd be glad to.
SloRoll is offline
post #28 of 28 (permalink) Old 05-19-2004, 12:29 PM
SloRoll's Avatar
Here, check this out.
http://www.ultralightnews.com/pilots...safetywire.htm
SloRoll is offline
