i need some help from those with race body work. - Chicagoland Sportbikes
post #1 of 17 (permalink) Old 03-24-2005, 06:50 PM Thread Starter
wtf! is this normal??
2000 zx9r with hotbodies race work.
i just installed all the body work, so i could start cutting the upper, to drill for the frame sliders.
anyway, i know what i am doing and lineing the parts up and what not, i havent had a problem yet with just some common sense to figure things out.
anyway, the bottom belly pan is touching the grease nipple on the bottom of the swing arm pivot "the bottom of the rear shock" and when i bounce the rear end up and down, i see the left side belly and lower side flex in and out ofcourse due to the pressure point.
is this shit normal?
post #2 of 17 (permalink) Old 03-24-2005, 07:11 PM
From everything that I see and read Hotbodies bodywork doesn't fit all that great. Would it be possible for you to cut a notch in the bellypan for the grease nipple?
post #3 of 17 (permalink) Old 03-24-2005, 07:13 PM
Is teh grease nipple straight out or is it a 90 deg bend one?
post #4 of 17 (permalink) Old 03-24-2005, 07:55 PM Thread Starter
yeah i could cut a hole in the belly but what good would that do to retain the fluids incase of a leak or what not.
and its stright rob.
post #5 of 17 (permalink) Old 03-24-2005, 07:59 PM
1 option: grease the swing arm then replace the fitting with a plug.
YTRAP is offline
post #6 of 17 (permalink) Old 03-24-2005, 08:03 PM Thread Starter
YTRAP how much clearance do you have, jim said you have hot bodies on your 9r?
post #7 of 17 (permalink) Old 03-24-2005, 08:04 PM Thread Starter
can you also post a picture of your bike SIDE profile?
thanks man.
i am just trying to see something.
post #8 of 17 (permalink) Old 03-24-2005, 08:58 PM
Then replace it with a 90 deg one or like ytrap said, put a pipe plug in its place after greasing the pivot.
post #9 of 17 (permalink) Old 03-24-2005, 09:03 PM Thread Starter
its so small already plus like i said, i think it needs a 1/4 inch, which is larger then the grease fitting anyway. i think i just might have to live with it, as long as it doesnt mess with my suspension free flowing.
post #10 of 17 (permalink) Old 03-25-2005, 08:06 AM
Wannabe racer
lovebothkats's Avatar
How you found us: Duh!
Welcome to the club of Hotbodies owners Ken THEY SUCK!!! I bought a set for the other SV and same thing they didn't clear certain areas, hell the lower smolders from touching the damn exhaust when it was still stock exhaust. They are crap and I would never buy another set ever again.
lovebothkats is offline
post #11 of 17 (permalink) Old 03-25-2005, 08:06 AM
How did you put that again? Oh yes, fit them BEFORE you paint.
Here's what you do now: Cut hole around the grease fitting. Put a large bead of silicone caulk around the edge of the hole to keep your fluid retention properties of the belly pan.....problem solved.
taziscool is offline
post #12 of 17 (permalink) Old 03-25-2005, 09:12 AM Thread Starter
thanks dave its seems likem this is the fact...lol
tazz i did, plus i am not done, i have to do the upper peice, but i needed to cut the frame slider holes, thats what made me complete the whole thing, nothing wrong with my holes, or screw holes, or placement off anything, its just that 1 spot of clearance.
post #13 of 17 (permalink) Old 03-25-2005, 09:22 AM
Does this help?
YTRAP is offline
post #14 of 17 (permalink) Old 03-25-2005, 09:24 AM Thread Starter
yep, thanks.
post #15 of 17 (permalink) Old 03-25-2005, 09:55 AM
Guest
Posts: n/a
+1 on this. I would not use them if they were free. The agravation is to much for me to handle.
post #16 of 17 (permalink) Old 03-25-2005, 10:05 AM Thread Starter
+1 i wont use them again i had to reenforce 3 bad areas on them cause of thin resin spots.
post #17 of 17 (permalink) Old 03-25-2005, 10:52 AM
Really too bad Multi-tech went under after teh fire. Great bodywork.
