Trackday tire pressures... - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 06-27-2005, 07:02 PM Thread Starter
StenMK1's Avatar
Sportbike: 95 GPz 1100/ 94 ZX-9R
Years Riding: a very lonnggg time
I remember there being a question about tire pressures for Diablo Corsa tires, I was way off. Anyway, I also remembered a Roadracing World article on tires. So I pulled out the story to see what psi's they were running. They tested 8 street/trackday tires. The pressures are the manufacturers recomended settings.
Avon Avaro AV49/50SP Pro 31psi/30psi front/rear
Bridgestone BT014 31/30 psi
Continental Conti Force Max 31/31 psi
Dunlop D208GP 31/31 psi
Maxxis Supermaxx 30/30 psi
Metzler SporTec M1 32/32 psi
Michelin Pilot Power 31/28 psi
Pirelli Diablo Corsa 32/32 psi
So there you have it. I hope this helps somebody out there.
StenMK1 is offline
post #2 of 8 (permalink) Old 06-28-2005, 09:48 AM
Thunder man
zeus-9R's Avatar
Years Riding: A long time
The Pirelli Diablo Corsa runs better at 32 front 34 rear psi. You get more life from the tire and no loss of traction.
Brent
Nesba Dir/CR #319
zeus-9R is offline
post #3 of 8 (permalink) Old 06-29-2005, 11:49 AM
NickIF's Avatar
Sportbike: FJR1300
32/34 for the corsa's is what they reccommended in the beginners meeting also (nesba)
NickIF is offline
post #4 of 8 (permalink) Old 06-29-2005, 12:34 PM
dano5150's Avatar
Sportbike: All kinds.....
Years Riding: motorcycles are dangerous
How you found us: as
I'm pretty sure that the Pirellis are ment to be run at 35psi hot. So they might say to start off at 32 in the front and 30ish in the rear.
I'm not sure about Dunlops
And the Michelin Pilots Power Races are 22.5 psi in the rear and 31ish in the front.
I think when I tested the power roads I ran 28 rear and 31.5 front. (which are awesome tires (for a street tire)I did 1:13.2 at blackhawk)
post #5 of 8 (permalink) Old 06-29-2005, 02:49 PM
I'm running 32/34 on my DC's as well. My rear tire heated up to over 40 last Saturday and when I emptied a little air from the rear tire it felt a lot better out there on the track.
post #6 of 8 (permalink) Old 06-29-2005, 11:00 PM
NickIF's Avatar
Sportbike: FJR1300
I think I might try 32/32 at BHF next month, especially considering my rear shot out from under me when it was at 32/34
NickIF is offline
post #7 of 8 (permalink) Old 06-29-2005, 11:09 PM
stuck in 6th gear
Ernie's Avatar
should probably check it periodically throughout the day. summer track days can heat them up to something unexpectedly high
Ernie is offline
post #8 of 8 (permalink) Old 06-30-2005, 02:02 PM
Thunder man
zeus-9R's Avatar
Dan you are correct but that is for the Supercorsa race tire. The above pressures are for the Diablo Corsa, which is made different from the race tire. They need more pressure for the sidewall construction.
Brent
Nesba Dir/CR #319
zeus-9R is offline
