Wtfek? How does this work. - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 02-28-2007, 05:11 PM Thread Starter
SNF
Gixxer6Dan's Avatar
Sportbike: Nothing.
Where the hell does this speedo bolt to?
I'm somewhat mechanically inclined but I have no idea how to attach the speedo to this thingamajig!
Theres two holes for the two holes on the bottom of the speedo, but theres nothing to screw them into.. and their on opposite angles, the speedo is like this ( / ) and the holes are like ( \ ) that as opposed to lining up ( / / ) perfectly. The top piece that is supposed to clip onto the bracket is fine, its just not a very tight hold.. but it works as intended.
Also what are the two small slits on the sides of the bracket, they slide side to side and were zip tied so they wouldnt fall out when they arrived.
http://home.comcast.net/~dan_gizynski/1.jpg [this one is fairly large so I didnt put it in here ]
Gixxer6Dan is offline
post #2 of 9 (permalink) Old 02-28-2007, 05:19 PM
BFLY's Avatar
Sportbike: CBR1000/GSXR1000
How you found us: Buddy
Take the rubber out of the stock unit and move to the aftermarket one.
BFLY is offline
post #3 of 9 (permalink) Old 02-28-2007, 05:26 PM Thread Starter
SNF
Gixxer6Dan's Avatar
Sportbike: Nothing.
What rubber do you speak of?
This is how it bolted up to the headlight assembly..
post #4 of 9 (permalink) Old 02-28-2007, 05:39 PM
BFLY's Avatar
Ok then just find afew nut's to fit the bolts and use washers big enough to cover the opening.
Tell ya what sell me the 11th and I'll drive down and hook it up
BFLY is offline
post #5 of 9 (permalink) Old 02-28-2007, 05:42 PM
Buy Honda.
Streaker is offline
post #6 of 9 (permalink) Old 02-28-2007, 06:05 PM
That braket is for an 04 GSXR...
This is how mine looks.
post #7 of 9 (permalink) Old 02-28-2007, 06:44 PM
1 piece at a time
hexraptor's Avatar
Years Riding: Since I joined!
zip ties fix everything!
- Steve
hexraptor is offline
post #8 of 9 (permalink) Old 02-28-2007, 09:26 PM
Dual purpose.....
They fix it .... true dat. But if you have an off they break before
the tabs on the cluster break off, like if you used screws.
Note the small holes drilled in the cluster for the zippers.
post #9 of 9 (permalink) Old 02-28-2007, 10:27 PM Thread Starter
SNF
Gixxer6Dan's Avatar
Sportbike: Nothing.
Originally Posted by DANS SIG
2004 Pearl White GSX-R 600
Thats why I posted up how does it work?
Thanks for the picture Blarney, ill probablly do something similar then.
