190 on a 750? - Chicagoland Sportbikes
post #1 of 65 (permalink) Old 05-08-2007, 05:14 PM Thread Starter
190 on a 750?
Does anyone run a 190 rear on their 750? I've been told its a better setup than the 180 because of the bigger contact patch. Having never tried it, I'm curious to see what other 7-fiddy track riders think.
Discuss
post #2 of 65 (permalink) Old 05-08-2007, 05:19 PM
doesnt the 750 have a half inch narrower rim than the 1k? I'd think this would affect contact patch size when comparing similar sized tires, no?
post #3 of 65 (permalink) Old 05-08-2007, 05:20 PM
Bigger contact patch...maybe. Easier or harder cornering would be my concern though.
post #4 of 65 (permalink) Old 05-08-2007, 05:21 PM
Most liter bikes on the track go down to a 180.
post #5 of 65 (permalink) Old 05-08-2007, 05:24 PM
I sense a slide the fork tubes up to compensate comment coming.
post #6 of 65 (permalink) Old 05-08-2007, 05:32 PM Thread Starter
I almost put it in the original post to pre-empt it
post #7 of 65 (permalink) Old 05-08-2007, 06:07 PM
Resident Smartass
RavinRaven's Avatar
Sportbike: 2010 R1 Raven ('05 R6 Raven SOLD)
Years Riding: Many moons
How you found us: Magic
Send a message via AIM to RavinRaven
Run the tire size that was intended for that particular width wheel. Anything else will mess with the handling.
RavinRaven is offline
post #8 of 65 (permalink) Old 05-08-2007, 07:29 PM
I'm a blessed man
ronhix's Avatar
Sportbike: GSXR 1000
True, it will probably mess with the handling in a good way AND provide a larger contact patch. I say run the 190. I think all the AMA teams run 190's on their 600's.
Ron Hix
MTD CR #975
ronhix is offline
post #9 of 65 (permalink) Old 05-08-2007, 07:35 PM
Put one of those really cool 330s on there with the 2 seperate chain set-up. Not only will you be cooler than everybody, you will lose about 103 RWHP.
Sorry, I cannot find a picture. I am sure you guys have seen them though.
Streaker is offline
post #10 of 65 (permalink) Old 05-08-2007, 07:37 PM Thread Starter
Thats exactly what I was thinking. Were you on a 750 before you got your 1k?
I think I might experiment with a 190. I have a set of Supercorsas with the 190/55 that came off the MV. They've got ~500 street miles on them, so I'm not totally sure on using them though. I've also got a pile of 180 PR4s to burn up.
post #11 of 65 (permalink) Old 05-08-2007, 07:43 PM
are they running a stock sized rim? pretty sure you can put a 1k rim on the 750/600 with the right spacers.
post #12 of 65 (permalink) Old 05-08-2007, 11:26 PM
Resident Smartass
RavinRaven's Avatar
That is incorrect. Please stop giving bogus advice. Kthanxbye.
http://www.sportrider.com/tech/tires...206_tire_size/
post #13 of 65 (permalink) Old 05-08-2007, 11:31 PM Thread Starter
Have you been on a track with Hix? The man knows his shit.
Second, that test used a 190/50. No one uses those, because they flatten out and handle like shit, even on 6" rim. Finally, the test didn't change the geometry, which is a must do when changing tires size.
So do you have any firsthand knowledge, or are you just regurgitating what you've read in the rags?
post #14 of 65 (permalink) Old 05-08-2007, 11:50 PM
Resident Smartass
RavinRaven's Avatar
I have not been on the track with Hix, nor is that relevant to the question at hand. The "test" may have used a 50mm tire, but that is irrelevant as well.
That is but one source that I chose to cite, to make my point. The whole question was about using a bigger tire than what is supposed to be used on a specific rim width. Search the internet. Im sure you'll find more information on the subject.
Oh and you'll never see me run a 190 tire on a wheel that was intended for a 180.
post #15 of 65 (permalink) Old 05-08-2007, 11:54 PM
I vote Hix
post #16 of 65 (permalink) Old 05-09-2007, 12:00 AM Thread Starter
I vote Hix
Yeah, so do I.
Typical case of the "instant expert- just add internet!" Can't even come up with a properly done 'test'
post #17 of 65 (permalink) Old 05-09-2007, 12:02 AM
Yeah, so do I.
Don't know the man myself but somethin tells me he has raced a few tires in his day and that whole crew (you know who you are ya damn track heads) seems awfuly reliable when it comes to bike info
post #18 of 65 (permalink) Old 05-09-2007, 12:16 AM
Gixxer Rider
Nolan1300's Avatar
Sportbike: K6 & K9 GSXR1000s
Years Riding: 12th season
Not these newer liter bikes. You need as much contact patch as possible. I tried a 180 208GPA once, it sucked even at my slow speeds. I had the rear step out on me one too many times.
I vote with HIX too.
Track Junkie #79
Nolan1300 is offline
post #19 of 65 (permalink) Old 05-09-2007, 12:36 AM
Resident Smartass
RavinRaven's Avatar
Yeah, so do I.
Not even close.
post #20 of 65 (permalink) Old 05-09-2007, 01:13 AM Thread Starter
As it turns out, the Ten Kate Honda that continues to dominate World Supersport is running *gasp* a 190 on their 5.5 rims
post #21 of 65 (permalink) Old 05-09-2007, 01:43 AM
jimzx9r's Avatar
Sportbike: .
Did you know that mountains on Antarctica appear yellow instead of blue?
Run the 190 and test, worst case it doesn't work and you're out the $$$ for the mounting...if you even have to pay for it.
jimzx9r is offline
post #22 of 65 (permalink) Old 05-09-2007, 08:42 AM
BH
BH's Avatar
Sportbike: KTM
How you found us: find who?
[B]
50mm?
you may want to do some more internet research on tire sizes
BH is offline
post #23 of 65 (permalink) Old 05-09-2007, 09:03 AM
Semper Fidellis
Devil Dog's Avatar
Sportbike: NADA
Years Riding: Since 1984
Tell you what, call Safety First Racing http://www.safetyfirstracing.com/ 847-357-1319 and ask for Kevin Hanson or Jim Rashid. Ask them what size they use on their race bikes, and ask this question to them. Hix is correct, and the faster you go the more contact patch you'll need when leaning it over at higher speeds with greater lean angle.
My VB Garage
Devil Dog is offline
post #24 of 65 (permalink) Old 05-09-2007, 09:16 AM
that's interesting, and the kind of feedback I was curious about. i know the 1k has a 6", and i think the 750 is still a 5.5 but wasnt sure if they upped it with the k6 redesign.
post #25 of 65 (permalink) Old 05-09-2007, 09:18 AM
Resident Smartass
RavinRaven's Avatar
Thanks. I'll give them a call.
post #26 of 65 (permalink) Old 05-09-2007, 09:28 AM
Must... brake... later...
mikdivad's Avatar
Here's some additional info. that you may find helpful:
The 190 size on liter bikes is definitely the way to go, because the manufacturers design the geometry around the bigger tire profile, however I think the 750's come with 180 size tires and therefore the geometry is setup as such. On 600's or 750's, if you don't have a ride height adjustable rear shock to compensate for the change in the geometry, you will be in for some eye opening experiences on the track.
For example, on my R1 last year I ran a Dunlop AMA-spec slick with the tall 195/70 size without changing my geometry setup at RA, and it made for a miserable day. It would headshake anytime the bike got up to speed down the straight. The bike turned in well, but it there was a nervous twitchiness mid-corner. I was able to tame the setup by lowering rear ride height to restore the original geometry, but the bike still had a twitchiness about it in the corners. However, the biggest advantage of tall profile rear tires was experienced on the exit of corners. There was so much confidence getting on the gas at the exit that I had never had before on my R1. I could be more aggressive with the throttle and as a result get great drives coming out of corners... that made up for all the other flaws. I could have probably played around with the suspension settings more, but it was the end of the season and ironically the end of the line for the R1 at the following track day.
Bottom line-- If you can adjust ride height in the rear and are willing to spend time chasing the right setup, the tall profile tires will pay great dividends. If you just want to ride a proven geometry without having to tinker around too much, 180's are cool... but rarely do I meet track day guys who don't live for tinkering around with their rides
mikdivad is offline
post #27 of 65 (permalink) Old 05-09-2007, 09:28 AM
Pretty sure Hix knows what he's talking about
post #28 of 65 (permalink) Old 05-09-2007, 09:32 AM
that's not fair though, his bike is designed around the 190. We need a 750 rider to chime in.
post #29 of 65 (permalink) Old 05-09-2007, 09:38 AM
mikdivad's Avatar
Just another note of clarification-- Most stock rear shocks don't have ride height adjustment, but if you have a newer Ohlins or Penske shock on your 750 with RHA than by all means it is worth a shot. Michelin makes a 190/55 that is not as radical as Dunlops tall 190 that really worked well for me last year too once I got the geometry all sorted out. It takes about a good 1.5 track days worth of riding to sort out the suspension to where you are happy with it. The process is sped up dramatically if you have suspension support at the track.
mikdivad is offline
post #30 of 65 (permalink) Old 05-09-2007, 09:42 AM Thread Starter
Good stuff, thanks David
The shock on the GSXR is the stocker.
