K6 with slicks - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 05-13-2007, 07:10 PM Thread Starter
Registered Loser
Otis's Avatar
Sportbike: 06 gsxr 1k
How you found us: i forgot
K6 with slicks
I'm in the process of setting up the k6 for the track.
Among other things, I got some 125/80, 195/70 slicks. I probably don't need them, but i wanted to see what they felt like.
I did some 'testing', and found the bike goes into a pretty bad headshake above 120 with the throttle pinned.
I did a bit of research and conclude that:
The rear tire need to be set towards the back further.
The stock suspension aint gonna cut it anymore.
I'm pretty light, and have, til now, been able to tweak the stock stuff to where im happy with it.
I think im looking at a chain, sprockets, and at the very least a good shock.
Any comments or suggestions would be appreciated.
Otis is offline
post #2 of 9 (permalink) Old 05-13-2007, 07:16 PM
SV650N
crashomon's Avatar
Sportbike: 2005 SV650SN
Years Riding: Since 1980
How you found us: craigslist
Have you done anything with the front forks? changed fork oil or springs? does your bike have a steering damper on it? (if so, is it stock?)
crashomon is offline
post #3 of 9 (permalink) Old 05-13-2007, 08:09 PM
if the bike felt fine before with a 180/?? what ever rear and now it feels like its going into head shakes with the new tire 195/70
thats cause the new HIGHER rear tire just made the steering more aggressive and thrown the swing arm alignment along with the rake and trial of the front end off.
you need to adjust the rear ride HEIGHT "not pre load" when you switch from tire to tire PROFILES.
post #4 of 9 (permalink) Old 05-14-2007, 07:08 AM Thread Starter
Registered Loser
Otis's Avatar
I havent done squat to the front, except set the preload, comp and rebound to my liking. I really dont wanna spend 2 grand on cartridges.
The dampener is stock, but with heavier oil in it. I have an ohlins on the way. I think it may mask the problem rather than correct it.
The headshake does not occur with a 180 gp tire or a 190 street tire.
I think ill get a penske rear shock, I cannot lower the rear ride height with the stocker. (which i think would be neccesary to offset the geometry)
Otis is offline
post #5 of 9 (permalink) Old 05-14-2007, 12:44 PM
mgentz's Avatar
Sportbike: rolling chassis
Years Riding: longer than before
How you found us: well, I was on the internet looking for ummm...pictures and....
you need to change you geometry to match the new tires.....in this case, lower the rear and lift the front (lower the tubes in the triples)
mgentz is offline
post #6 of 9 (permalink) Old 05-14-2007, 12:51 PM
I'm a blessed man
ronhix's Avatar
Sportbike: GSXR 1000
If you can't lower the rear cause your stock shock has no rear ride height adjustment, then raise the front (drop the forks DOWN in the triple trees).
Ron Hix
MTD CR #975
ronhix is offline
post #7 of 9 (permalink) Old 05-24-2007, 08:46 AM
Stroked77
Guest
Posts: n/a
post #8 of 9 (permalink) Old 05-24-2007, 11:57 AM
Track Whore
Sportbike: R6
Years Riding: I am slow
How you found us: Wink, Hix, NESBA
Sounds like you have a set of the non-Ntech Dunlop slicks. yep, you need to raise the tripple (less for tube showing) like Ron said to help stop that.
Julio Caliente is offline
post #9 of 9 (permalink) Old 05-24-2007, 11:58 AM
Track Whore
Sportbike: R6
Originally Posted by Stroked77 View Post
What he means is to raise the nose of the bike. To do that you need to have less for tube showing. As Ron put it as "dropping the forks down the tripple" which is the same as showing less for tube, raising the tripples, etc....
