rebound tear - Chicagoland Sportbikes
post #1 of 12 (permalink) Old 08-01-2007, 11:33 AM Thread Starter
DieselBoy's Avatar
Sportbike: 08 R6 , CRF250R
rebound tear
My PP have the same rebound tear pattern as http://www.feelthetrack.com/tire-wear.html
However, I'm confused which direction my rebound should be changed. I'm assuming it should rebound faster.
Just doublechecking.
CCS 787(ex). 08r6
DieselBoy is offline
post #2 of 12 (permalink) Old 08-02-2007, 10:21 AM
I'm no expert, but I did stay in a Holiday Inn Express last night.
If I understand correct. If you do truly have rebound tear, then I believe you are correct. Your bike should rebound faster. Or.... You should decrease the amount of rebound damping. The same thing stated two different ways.
post #3 of 12 (permalink) Old 08-02-2007, 10:35 AM
We ride tomorrow?
jkrueger's Avatar
Sportbike: i like 04's
Years Riding: not enough
How you found us: NESBA.com
go 6 clicks out, ride it if it cleans it up problem solved if not go back to the original setting and then 6 in the other direction
it might not clean up perfectly right away but you should notice it starting to smooth itself out
jkrueger is offline
post #4 of 12 (permalink) Old 08-02-2007, 10:43 AM
Decrease damping/faster/unscrew is correct. Try different settings and keep track of how the bike felt and how the tire wears each time. Good luck.
post #5 of 12 (permalink) Old 08-02-2007, 01:35 PM
Ron? Ron Hix... Is that you?
post #6 of 12 (permalink) Old 08-02-2007, 01:46 PM
We ride tomorrow?
jkrueger's Avatar
nope its me, i just spread the good word when i get the chance.
If Ron was posting under my name there would be another one of these starting up
http://www.nesba.com/TrackTalk/bb/Fo...ML/002415.html
jkrueger is offline
post #7 of 12 (permalink) Old 08-02-2007, 01:52 PM Thread Starter
DieselBoy's Avatar
Thanks all
I've been "noticing" the rear sort of getting "loose" over bumps and elevations. Hopefully, the tweak will help that too.
CCS 787(ex). 08r6
post #8 of 12 (permalink) Old 08-02-2007, 01:58 PM
Diesel....
You can verify your rebound setting visually pretty accurately.
Stand next to the bike and bounce the back of it deeply.
It should move on a three count.
one-two-three say it as you do it.... one-two-three
down is 1
up is 2 - 3
If it is coming back too fast, the rear tire is unloading and losing grip.
You would need to add rebound ( clockwise ) to correct this.
I'll be the contrary opinion here and bet your rear is rebounding too fast.
Same in the front BTW.
post #9 of 12 (permalink) Old 08-02-2007, 03:58 PM
I'm a blessed man
ronhix's Avatar
Sportbike: GSXR 1000
It really is sweet when you can just kick back and watch your word spoken by others. Jesse, I love you man.
Ron Hix
MTD CR #975
ronhix is offline
post #10 of 12 (permalink) Old 08-02-2007, 09:27 PM Thread Starter
DieselBoy's Avatar
down is 1
up is 2 - 3
rear shoots up almost immediately.
front slower but noticably less than in 1 sec.
ok , now I feel like I have just opened pandora box...
CCS 787(ex). 08r6
post #11 of 12 (permalink) Old 08-02-2007, 09:50 PM
Nope...
Suspension is complicated.... not impossible.
What you are looking for is BALANCE.
Stand next to the bike facing it.
Put one hand on the center of the steering stem.
Put the other hand in the center of the seat.
Stroke the suspension.
Both ends should fall and rise with the SAME CADENCE.
One.....two-three
If it is not balanced, this same action occurs while you are riding.
The imbalance shifts weight and therefore traction from one end to
the other over deformities in the track..... this is bad.
Balance is key to maintaining even traction or irregularities.
Add rebound to the rear to slow it down, your tearing will disappear.
Get the cadence right.... it's magic
post #12 of 12 (permalink) Old 08-02-2007, 09:52 PM
Or alternately..... Stop by and see me in the pits and I'll help you set it up.
