Street/Track Conversion: Turn signals - Chicagoland Sportbikes
post #1 of 20 (permalink) Old 03-17-2008, 09:36 AM Thread Starter
My turn signals and brake light are after market. The front ones are soldered and I need a quick connect style so I can take them off and put on more simple than cutting and soldering every time.
What are some good connectors that are waterproof?
post #2 of 20 (permalink) Old 03-17-2008, 09:39 AM
stockers!!!!!
post #3 of 20 (permalink) Old 03-17-2008, 09:40 AM
Do you really need to take them off? I left my rear turn signals on and I'm just taping them. They will however most likely break when I crash, but it's only $20 and a pain to remove.
post #4 of 20 (permalink) Old 03-17-2008, 09:40 AM Thread Starter
Yes, the front ones are hard wired, ie "soldered" on. I am pretty sure the rear ones I have a clip for. Been too long since I looked at the damn bike.
post #5 of 20 (permalink) Old 03-17-2008, 09:48 AM
So are you just looking for a good solderless connector for them, or do you need hardware for quick removal too?
post #6 of 20 (permalink) Old 03-17-2008, 09:53 AM
just some cheap but connectors and a bit of dielectric grease. all you need and all parts can be sourced at radio shack for a few bucks
post #7 of 20 (permalink) Old 03-17-2008, 09:54 AM Thread Starter
Solder free connectors, ie quick connectors, or butt connectors or spade. Just wondering if anyone else is doing this since I put my turn signals on thinking I'd never take them off, thanks CLSB for tracking me!
post #8 of 20 (permalink) Old 03-17-2008, 09:54 AM
get the connectors from the stockers, they work perfect. why did you cut them off? Always reuse them and solder them to your new indicators.
post #9 of 20 (permalink) Old 03-17-2008, 09:55 AM Thread Starter
Thanks tony!
post #10 of 20 (permalink) Old 03-17-2008, 09:55 AM
turn signals for the street?!?!?! who knew!
post #11 of 20 (permalink) Old 03-17-2008, 09:57 AM Thread Starter
Hardwired the aftermarket ones thinking I didn't need the quick connectors. N00b to track, never even heard of track days when I got the thing last year.
post #12 of 20 (permalink) Old 03-17-2008, 09:59 AM
dont you ever remove the bodywork though? note to other modders out there, always retain your disconnects!!!
post #13 of 20 (permalink) Old 03-17-2008, 10:01 AM Thread Starter
Yeah, I have some weird aftermarket ones where they will remain in the body work unless you remove the wiring. Stock disconnects... grrr. I have to look in my box of stock stuff to see if I still got em.
Thanks though, think I found a solution!
post #14 of 20 (permalink) Old 03-17-2008, 10:01 AM
Like Tony said, just cut the cables and splice in solderless connectors from Radioshack. I like the spade kind. If you need help let me know. By the way, I think Home depot has the same connectors for cheaper.
post #15 of 20 (permalink) Old 03-17-2008, 10:02 AM Thread Starter
I've looked at spade and butt, just wondering which would be better for a few times being removed and reconnected again. The grease will be key. Then just some electrical tape over the whole thing since I'm OCD about this shit.
post #16 of 20 (permalink) Old 03-17-2008, 10:03 AM
Just go to the hardware store and buy some weather proof quick disconnects. You'll need 8, one for each positive and negative wire on each turn signal.
You can buy these really cool quick disconnects that you push a small flat blade screwdrive in and it releases and grabs the wire when you pull the screwdriver out.
Or you can just get a quick disconnect like this.
Grainger kicks ass http://www.grainger.com/Grainger/items/1DMW2
post #17 of 20 (permalink) Old 03-17-2008, 10:04 AM Thread Starter
Even better. Is this what you have used? Even for stranded wires?
post #18 of 20 (permalink) Old 03-17-2008, 10:05 AM
dammit Bobby, I told you that you'd regret soldering those fuggers on at Winks!
post #19 of 20 (permalink) Old 03-17-2008, 10:06 AM Thread Starter
They were soldered before!
post #20 of 20 (permalink) Old 03-17-2008, 10:09 AM
Well you didn't hafta solder them again! Then again you didn't know where you're stock connectors were so we didn't really have a choice either.
