RAW Image Noise - Chicagoland Sportbikes
post #1 of 24 (permalink) Old 04-04-2008, 05:02 PM Thread Starter
Yes, That is a scar...
JayHRC51's Avatar
Sportbike: '00 Honda RC 51 (sold)
Years Riding: 2 years
How you found us: worked with HD Tony's wife
RAW Image Noise
Quick question...
I'm working with my 1st SLR, a Canon 40D, and I've recently started making exposures in the RAW format. I purchased it right after Christmas and I've made 2884 images to date. Obviously a lot of garbage images that were just test shots or just learning settings and what not.
Question is this, are RAW images just "noisy"? Every single image that I zoom to 100 or 200% in digital photo professional (canon supplied software) has a ton of noise. By a ton I mean that it's really noticeable. I have a bunch of example images from all different lighting conditions, indoors, outdoors, high ISO, low ISO, all different f-stops and shutter speeds...I almost always shoot in manual. I realize that my camera isn't a full on $6k pro model, but I was expecting better results than what I've been getting.
So, you guys that have been using SLR's for a while, is removing noise from every single image just normal when working with RAW, or am I not doing something right?
Thanks for any feedback and sorry if I didn't include info shooting info. Just let me know if you need more info to better answer.
"I just want to say good luck, we're all counting on you"
JayHRC51 is offline
post #2 of 24 (permalink) Old 04-04-2008, 06:12 PM
BusaDave's Avatar
Years Riding: Lost Track
How you found us: Tony
I don't recall that being a problem.
Dave
BusaDave is offline
post #3 of 24 (permalink) Old 04-04-2008, 06:13 PM
Formerly RwS Films
PaulieRedCoat's Avatar
How you found us: Other
Examples?
Is it happening at all ISO settings? edit: sorry just skimmed.
Shoulda got a Nikon. LOL. j/k I've never had any issues with noise in RAW so I can't really offer many suggestions.
Namaste
PaulieRedCoat is offline
post #4 of 24 (permalink) Old 04-04-2008, 06:20 PM
What RWS said.
Post an example and leave the meta data in it. I'm sure a good amount of us could help you out and lead you in the right direction.
It sounds like you ISO is high. the ISO number should be around 200-400 without getting TOO much noise.
post #5 of 24 (permalink) Old 04-04-2008, 06:27 PM
jaysun0ne's Avatar
Sportbike: 91 hawkgt & 05 rc51
Years Riding: 8
How you found us: fellow rider mvrc51
i got a canon g6 (not a SLR) but it happens to me about 50% of the time in low light
and more often when in RAW size
never been able to figure it out my self.
jaysun0ne is offline
post #6 of 24 (permalink) Old 04-04-2008, 07:04 PM
I'm guessing your point and shoot has a noise reducer when compressed into a Jpeg.
In other words, jpeg is better for low light.
post #7 of 24 (permalink) Old 04-04-2008, 07:50 PM
BusaDave's Avatar
Longer exposures and higher ISO values will both accumate more noise for different reasons. Longer exposure allows the noise of the sensor to accumulate while the higher sensitivity amplifies the noise. Naturally the combination creates a double-whammy (high ISO + long exposure).
The image processor probably filters this noise in JPEG mode to some extent while in RAW mode it does not. The advantage of RAW is that you have complete control over the post-processing. In JPEG mode the camera makes an educated guess what processing to do (along with some settable parameters).
For longer exposures there's a mode that can take two pictures and compare them to eliminate noise. I haven't tried this out. It's only really good for still shots. I have no idea how it would look on motion.
p.s. I shoot in JPEG Large/Fine probably 99% of the time. I only use RAW when I want to do ALL the post-processing myself.
Dave
BusaDave is offline
post #8 of 24 (permalink) Old 04-04-2008, 09:26 PM
jaysun0ne's Avatar
Years Riding: 8
thanks i will keep that in mind
post #9 of 24 (permalink) Old 04-04-2008, 10:04 PM Thread Starter
JayHRC51's Avatar
I'll post an example with the meta data shortly. I rarely ever shoot above ISO 200. The example that I post will have been from this afternoon
JayHRC51 is offline
post #10 of 24 (permalink) Old 04-04-2008, 11:12 PM Thread Starter
JayHRC51's Avatar
I've converted the image to a jpeg and tried to resize it 3 times, and I still can't get it to post. Where can I post the full size image at? Or I can just email the original RAW file if that helps. Let me know what the best way is to make things easiest for you to view and that's what I'll do.
Thanks again for your help
JayHRC51 is offline
post #11 of 24 (permalink) Old 04-06-2008, 08:00 AM Thread Starter
JayHRC51's Avatar
Okay, here is a crop from a test shot yesterday. At 100% is doesn't look too bad, but at 200% you can really see how noisey the image is. At least in Photoshop and Digital Photo Proffesional you can. Also, here is the meta from the original shot.
File name
IMG_3121.CR2
Camera Model Name
Canon EOS 40D
Shooting Date/Time
4/5/2008 13:05:36
Tv(Shutter Speed)
1/200Sec.
Av(Aperture Value)
F11
Metering Modes
Evaluative metering
Exposure Compensation
0
ISO Speed
200
Lens
EF28-135mm f/3.5-5.6 IS USM
Focal Length
28.0 mm
Image size
3888 x 2592
Image Quality
RAW
Flash
Off
White Balance
Daylight
AF mode
AI focus AF
Picture Style
Landscape
Parameters
Tone Curve : Standard
Sharpness level : -
Pattern Sharpness : -
Contrast : 1
Sharpness : 5
Color saturation : 1
Color tone : 0
Highlight tone priority : Yes
Color matrix
Color Space
sRGB
File Size
13474 KB
Dust Delete Data
No
Drive Mode
Low-speed continuous shooting
GPS Data
Satellite signal status : -
Date(UTC) : -
Latitude : -
Longitude : -
Altitude : -
Geographic coordinate system : -
Owner's Name
Jason
JayHRC51 is offline
post #12 of 24 (permalink) Old 04-06-2008, 08:41 AM
jaysun0ne's Avatar
Years Riding: 8
wow that is really bad
its not that often the noise is that bad for me
i dont know enough to comment on settings
hope you figure that out
post #13 of 24 (permalink) Old 04-06-2008, 09:02 AM Thread Starter
JayHRC51's Avatar
I thought that looked pretty terrible for the ISO only being 200. If was shooting at 800-1600, then I would expect the results I'm getting. But at 200???
JayHRC51 is offline
post #14 of 24 (permalink) Old 04-06-2008, 09:48 AM
jaysun0ne's Avatar
Years Riding: 8
my g6 only has 50-400 iso settings
and with it at 400 at night trying to take shots of cityscapes is the only time it happens that bad
post #15 of 24 (permalink) Old 04-06-2008, 10:35 AM Thread Starter
JayHRC51's Avatar
SLR's have much larger sensors than other, more compact, cameras. That's why they can usually operate at much higher ISO's without as much noise. I know that the amount of noise that my old point and shoot had at ISO 100 should compare to around 400 or 600 on my SLR. I've seen other images, made on Canon 40D's at ISO 1600, that have similar noise that my images exhibit at half that level. Those examples that I've seen are what got me to start taking some sample shots, and prompted me to ask this question.
JayHRC51 is offline
post #16 of 24 (permalink) Old 04-06-2008, 10:52 AM
OK, allow me to step in.
#1 RAW mode has *no processing*, so you don't have all the fancy built in modes taking care of these details. You will have to learn to "process your negatives" yourself.
#2 Your image is terribly underexposed. Just like film, if you don't get enough light on the "media", you just won't get a proper image. When I first started with the Nikon D70s, I would terribly underexpose everything (I got the camera in winter so 95% of my shooting was low light), and the Nikon shows both noise, *and* harsh lines across the image that made me think I have a broken sensor....but in fact it was just my own lack of skill.
#3 Check your lens to make sure it's not a physical probelm with the lens which is causing underexposure. Take it off the camera and find the lever that actuates the aperture. Make sure it's snappy and doesn't stick.
#4 There could be problems with the camera body itself, though this is the least likely of all the options. Typically cameras are pretty solid.
Tips: Try different lenses, try different settings, try with/without flash, try in full daylight where the camera has a better chance of exposing.
post #17 of 24 (permalink) Old 04-06-2008, 11:37 AM
BusaDave's Avatar
I agree that the photo is under exposed. This places the detail at the low end of the sensor dynamic range and closer to the noise floor. You should probably increase your exposure by a couple of stops.
Dave
BusaDave is offline
post #18 of 24 (permalink) Old 04-06-2008, 12:41 PM Thread Starter
JayHRC51's Avatar
That image was just a cropped section from a full res photo. What is shown is a section from the backround of mid day image. The main subject is exposed just fine. I posted that section becuase it was what I could get small enough to post here, and still acurately show the level of noise I was talking about. If we need a better example with foreground exposure, then I'll post a new example in few minutes. I'll go outside and get a different shot right now. Or I can convert the enitire image to a jpeg, but I don't have anywhere to host a full res image.
I'll post back up in a few minutes once I get the new shot resized and converted to a jpeg.
Thanks,
JayHRC51 is offline
post #19 of 24 (permalink) Old 04-06-2008, 03:18 PM
BusaDave's Avatar
Have a look at the histogram for the portion you posted:
Notice that there is no information in the upper 20% or so? Also notice the big peak at about 40%?
Dave
BusaDave is offline
post #20 of 24 (permalink) Old 04-06-2008, 03:58 PM Thread Starter
JayHRC51's Avatar
So that is the cause of the noise, poor overall exposure? If that's the case, then it is just me, and not the camera or software being used to view the images. Obviously, not every exposure will be ideal, from a lighting standpoint, not an artistic standpoint. But will images always be noisy if not "perfectly" exposed for lighting conditions?
Does anyone want to see another exposure for an example or have we pretty much isolated the issue?
Thanks again, I appreciate the input and advice.
JayHRC51 is offline
post #21 of 24 (permalink) Old 04-06-2008, 04:11 PM
BusaDave's Avatar
There's still a possibility that you have a noisy sensor. You might want to check dpreview for this camera to see if they say anything about it.
Dave
BusaDave is offline
post #22 of 24 (permalink) Old 04-06-2008, 04:28 PM
Shut up all that noise!
It shouldn't matter what camera you purchased. What matters is your settings. And the main things to watch for are: ISO and F-stop. If those are not in sync with each other you'll get that oh so wonderful noise.
Sometimes though it doesn't hurt a picture. Meaning a picture might not come out the way you wanted it but sometimes the mistakes are sweet too!
Loki_D_Wolf is offline
post #23 of 24 (permalink) Old 04-06-2008, 04:57 PM
I have been quiet thus far because everyone speaking knows more than I do IMHO...
In any case...
I havent seen this posted, and I thought it might be of some help... I have always heard good things about it.
http://www.picturecode.com/download.htm
Noise Ninja (i know.. clever name.. right?)
Obviously it is not going to overcome grossly incorrect settings, but it could be very useful if you already have the picture and would just like to make it as good as you can make it..
post #24 of 24 (permalink) Old 04-06-2008, 06:27 PM Thread Starter
JayHRC51's Avatar
I like the cool "mistakes", I've had a few of those. They are a nice surprise when something cool happens that you didn't even notice at the time.
JayHRC51 is offline
