Camera battery question - Chicagoland Sportbikes
post #1 of 10 (permalink) Old 12-30-2009, 02:02 PM Thread Starter
Hey Photogs I have a question. I got a Canon D10 for Christmas and it came w with the NB-6L battery. It's the same size as the batteries from my old Canon, which are NB-4L models. My question: Can I use the older batteries in my new camera?
post #2 of 10 (permalink) Old 12-30-2009, 02:07 PM
under200's Avatar
How you found us: web search
Believe the only difference is the mAh.
the 4L is 760 mAh
and the 6L is 1000mAh
both 3.7v lipo single cell
more shots from the 6L but the 4L should work as long as it is physically the some size.
Under200
under200 is offline
post #3 of 10 (permalink) Old 12-30-2009, 02:18 PM
Pop it in and try it out worse case is the camera wont turn on
post #4 of 10 (permalink) Old 12-30-2009, 02:29 PM
If Canon designed then to use the exact same form-factor then they shouldn't be damaging to each other. Battery life would be the main difference based on the value quoted above.
post #5 of 10 (permalink) Old 12-31-2009, 04:02 AM
I woudl double check with the guys on POTN (www.photography-on-the-net.com) first just in case.
post #6 of 10 (permalink) Old 12-31-2009, 09:22 AM Thread Starter
the 4L is 760 mAh
Cool, thanks for the info. They are the same size, the contacts are in the same spot, too.
Ok, thanks I'll check this out.
post #7 of 10 (permalink) Old 12-31-2009, 09:50 AM
Audiofyl's Avatar
Sportbike: 600rr & Zuma125
Years Riding: since 2002
the voltage looks to be the same (3.7v) with the difference being the storage capacity.
as long as the terminals line up and it's the same size, it will likely work.
2003 CBR600RR
2009 Zuma 125
2005 VW Golf TDI
1994 Honda Civic Turbo
My Fuelly
Flickr
posterous
Originally Posted by shadrach
Audiofyl is offline
post #8 of 10 (permalink) Old 03-06-2010, 03:09 AM
Sportbike: hammythomas
Years Riding: hammythomas
How you found us: hammythomas
If there is no voltage difference than you can use that older battery to your new Canon D10 camera,But if there is major difference in voltage you can not use.
hammythomas is offline
post #9 of 10 (permalink) Old 03-06-2010, 06:10 AM
I switch batteries around in the Nikons all the time, no problems.
post #10 of 10 (permalink) Old 03-08-2010, 12:16 PM Thread Starter
Cool, thanks for the info guys. I'll try switching them around.
