Sorry maks, I had to get outta the office for a while. I just got back. Here it is:
BHF 4/04
Size is about 54.6 MB.
:helmet
BHF 4/04
:helmet
I know it was the 17th and 18th, but 04/04 refers to the MONTH and YEAR.... highspeed!maks said:Thanks dude.. and I meant to mention.. 4/04?? The days were the 17th and 18th and pretty sure the footage was from the 18th.
Ahar, that definitely makes more sense. My bad. So.. looka me haul ass on that video. Go me. Go.Chills said:I know it was the 17th and 18th, but 04/04 refers to the MONTH and YEAR.... highspeed!
yes!:cheersJRSMAIL said:Who is the rider with the camara? Chills?
Yep, that's me. That's also my video at Barber on the other thread.JRSMAIL said:Who is the rider with the camara? Chills?
Thanks, man. I always appreciate input. I didn't accelerate down the front straight as much because I needed new brakes. Since then I now have new lines and pads so I'll be getting on it more.racingxtc7 said:Some help from a racer.
You can excelerate alot farther down the straights, try being smooth when releasing your clutch on down shifts, work on using more of the track, try not the chop the throttle so much, and try to get to maintenance throttle as you lean the bike into the corners.
I keep it between 2nd and 3rd throughout most of the track. Sometimes I'll hit 4th on the front. I should be in a higher gear?Odysseys said:and stay in a higher gear![]()
I thought he was fine with what gears he was in!!!Odysseys said:and stay in a higher gear![]()
That's something I know I need to do. Just let of the brakes earlier and then get on the gas. My transition from brake to power isn't as smooth as it should be.racingxtc7 said:An good way to learn to go fast around turn is to let off the brakes earilier and earilier. Some people may til you to brake later but all that does is make you brake harder.
racingxtc7 said:we'll all be at BHF together may 24. I actually watched it again just to take lap times. your running 1:35 ave, some 37's and I clocked one 1:31.
Excuses, excuses.. your brakes couldn't possibly have been worse than mine. :twofinger :laughingChills said:I didn't accelerate down the front straight as much because I needed new brakes.
yeah, max was using his feet flintstone style and he pulled a 1:24.maks said:Excuses, excuses.. your brakes couldn't possibly have been worse than mine. :twofinger :laughing
