Ok so I was trying to reaffirm your data adding in a bit on the single soMichael said:
didn't i just say that? post whore! :twofinger![]()
and a note on single and dual .. if you want to run running lights on a dual filament, and you connect the wrong wire (ie running light wire from bike to signal wire on turn signal) the housing on cheaper after market signals (lp) will melt. when i was doing mine, i connected the wrong wire for like 10 seconds, and the signal was so deformed i had to buy a new set. i would assume you will have similar problems trying to run a single filament as running lights.
