Damn Honda electrical systems. Soemthing is screwed up wiht my electrical system. I studied the wiring dagram for a while and I think I'm half way there but I'm still missing something. Here's whats wrong.
Problem: when you turn the ignition to on, all the turn signals coem on. The biek starts and runs when I push the starter button, but will imediately die when I let go of it.
Started when: I was having trouble reconencting my tailights after the most recent BHF trackday. The pin connectors were bent. I had trouble gettign both the running light and brake lights to work on the left bulb. The good news is that problem seems ot be solved.
Current temporary fix: The bike runs fine if I disconnect the headlights and have the trun signal relay pulled (may not be nessesary).
Possible causes: I'm guessign a little here. I think it's related to the starter relay that kills the headlights when you push the starter. The headlight circut is routed through the engine stop relay, so in one positon that relay cuts the headlights. In the other it will cut the engine if there is a completes the circuit for the sidestand and bank angle sensor. I think there is a short in the headlight circuit. I can;t figure out hwo that is related to the turn signals though. I even have the realy pulled and if the headlights are plugged in, all four turn signals come on when I turn the ignition to "ON".
First I pull off all the covers and search for a shafed wire. Then I'll start checkign the relays. the problem seems somewaht intermittent. It will work fine one tiem, then the next I have ot start disconnecting lights.
Also, no fuses have blown.
Any thoughts??????:confused :confused :confused
