I think 11k is fair. MCC had a 99 with 6k between 10.5-11(that was sitting on the lot for a while)
maintence every 6K valve ajustment $400 clutch plates $150
i would plan on doing that 6-10k.
The rocker arm chrome flaking issue. once out of warranty can cost $100-200 a peice(i've heard some dealers have repaired under defect warranty). I had two replaced at 18k and 1 at 24k under warranty(2yr). If you want to go to the best service dept. in the area you'll be going to corsesuperbikes HMC ducati in milwaukee.
The bike doesn't like to sit in traffic it will overheat and boil, thats when the coolant overflow will crack(known recall). i've had mine replaced 3 times.
They do have a haynes manual for the 9x6 bikes.
You've gotta want it and not listen to anyone else, because all you're gonna hear is the Maint co$t and its uncomfortable,
i wish the dealer would go off that KBB figure and even a little less for my 30k mi duc.
