1 - 10 of 10 Posts
Got my new Ride......
Quick question..
Installing new rearsets (from Woodcraft) & Woodcraft say just reuse the old OEM bolts with threadlock. However, my bolts for the footpegs were a little mangled - so I just bought a new set of bolts from a Kawasaki dealer.
However, the bolts from the dealer have a red coating on them ! Does this coating take the place of the threadlock ? Do I apply threadlock ON TOP of the coating ? Do I have to worry about mixing different types of threadlock :confused
This may be a dumb question - but since I don't know the answer, it would be dumber for me not to ask.
Thanks
Nice choice in rearsets....don't know about the coating crap already on there.
I think all Kowasaki bolts have that on there because they rattle so much:rolleyes
I'm pretty sure that red coating is red LocTite, the stuff that's made to NOT come off, ever. It was on the rearset of my SV when I had to take mine off, and it took Pete, a T-wrench, and a vice to get that shit to move.
So yeah, I'd think you're covered.
Which reminds me, I better check that one, I don't remember LocTiting it back up!
Slow Poke
What does your shop manual say, factory stuff, factory procedures. Wouldn't the hardware be WAY cheaper? They are probably not even hardened bolts from kawi.
Put em in and torque em down, your good to go. That red stuff is a preapplied thread locker. It could be pre applied red loctite or it could be an epooxy lock type thread locker. Regardless, they should be ready to go.
Since you got bolts that have thread lock treated threads you should be ok to torque and go. If they weren't I would recommend to atleast use Blue Loc-Tite Red would be better but a bit harder to remove if needed. Pugsly found out ridin and loosin your peg isn't so much fun.
Yep - I will use those new bolts 'as is' and I'm gonna thread lock everything else.
Was anxious to try out the new rearset so I installed them with the old bolts. Got the shifter level & shift rod lined up. And even managed to rig up the brake cyclinder in the inside of the bracket (instead of the outside). I didn't use any thread lock - because I was planning on taking it all back apart - I just wanted to see how everything fit together and maybe take it for a "short" test ride. Well, I guess I stayed out playing too long and I dropped all 3 bolts holding on the brand new $80 shift lever !!! :(
I was going down the road and all of a sudden the shift lever is hangin of the bike being dragged along by the shift rod. It didn't get damaged all that much, but it put a good scratch on the bike frame when it first fell off and it kicked under the bike. So I pull over & I'm trying to find a few extra bolts some where on the bike so I can hook up the shift lever again & get home :laughing I couldn't find any the right size ! Tried to at least get the bike into second (with the bike standing still), but I couldn't. So I had to start riding the bike home & hang over the tank & reach down & shift with my hand ! up-shifting wasn't bad - but downshifting (one-handed, with no clutch, haning off the bike) was not a pretty sight
Anyway, I got home in one piece - won't make that mistake again.
Man with Big Hose
YES indeed.......losing a footpeg in turn 6 at Road America is NOT fun!!!!!!! Mental note.....use threadlock...use threadlock.
1 - 10 of 10 Posts
