1 - 11 of 11 Posts
You got the talkin' done
Trying to install Win2K3 R2 SP2 onto a new Dell 9G 2950. The driver for the Perc 5i controller does not exist on the Win2K3 CD. How do I "slipstream" the driver onto the disk?
I can't use a floppy and press F6 at setup. I need the driver to exist on the CD.
-= OuterSpace =-
Do you have the Dell CD that came with the server?....
You need to install the OS using the Dell install CD.
Yea, I know that works. I am not doing a fresh install.
I am upgrading from Win2K to Win2K3, but at the point in the setup where it prompts me for a driver, the USB mouse and keyboard don't work. Even if I boot to the CD to do the upgrade that way (and use F6 to get past the first time I need the driver) I still get prompted again later in the setup and at that point, the USB driver for the mouse and keyboard must not be loaded because they don't work.
-= OuterSpace =-
If that's the case I think your only plan would be to make a new bootable OS CD with the new Perc driver copied to it.
That's what I am asking - how do I do that?
apple FTW!
apple FTW!
Does apple have a server OS?
Idiot.
I am going to uninstall PC Anywhere to see if that correct the mouse/keyboard issue and I am going to copy the percsas.sys file its looking for into c:\winnt\system32\drivers and see if it picks it up.
There are tons of ways.
What burning software you have? Some have an option to make the CD bootable.
check this link > http://tacktech.com/display.cfm?ttid=157
What the OP is looking for is a program called Nlite (google it).
According to the docs, "nLite supports Windows 2000, XP x86/x64 and 2003 x86/x64 in all languages. "
This program does all the dirty work of slipstreaming drivers, updates, hotfixes, sp's, etc. Ultimately producing either a cd, or a burnable/mountable ISO file.
Best of all, it's free!
Njoy! :)
Thanks. MS has a article 814847 to slipstream hotfixes, but not just a driver.
I'll check out the nlite.
Uninstalling PcAnywhere prior to starting the upgrade solved my problem. At least now I can click OK and Browse and then point it to the percsas.sys file.
:cheers:
1 - 11 of 11 Posts
